A1278 (820-2936-A) green light no power
  • robertpritchard
    • Dec 2016
    • 61
    hello looking for some help.. i have a green light and everything is good with one wire circut,, PPBUS_G3H is reading 0.12 volt
    and is reading 0.00 short to ground. nothing is heating up and laptop was not water damaged whats the best way for me to find this short thanks
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: A1278 (820-2936-A) green light no power
    Inject low votage with high current( amp) on short line and observe the PCB short circuit will be heatup.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3597
      • slovakia
      beware of high current. u can blow component and pads with trace or weld it to another trace under it. start with low current like 1A
      • robertpritchard
        • Dec 2016
        • 61
        thanks very much for everyones help .. so i got a new power supply and found my short had to goto 3volt to find it but finnaly Q7630 got hot.. as soon as i took it off short to ground went away after replacing i now get 01.50 on PPBUS_G3H something is pulling it down and cant seem to find it any ideas thanks
        • robertpritchard
          • Dec 2016
          • 61
          light stays green when i attach a battery dont know if that might have anything to do with it.. anyone think i should try to reflow the gpu
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            reflow gpu is completely no sense.......
            u dont have ppbus g3h voltage stable ?
            it should be 12.5 volts.
            these is generated by u7000 and 2 mosfet near it.
            check u7000 voltages and if it get hot as battery light is controlled by it.
            • hackintoshmalang
              • Feb 2019
              • Indonesia
              Hi DellXPS15,
              i have mbp a1278 (820-2936B), my mbp is missing p5vs3_vo1 on pin 24 (u7200/tps51125)...but p3v3s5_vo2 on pin 7 is present, 5v3v3v_reg_en present on pin 13, pp5v_s5 is also presnt on pin 17.... could it be becaus e bad chip tps51125 for some reason cannot generate p5vs3.. (there are not shot to ground)
              Please help me, green light is present, when attach battery change into orange...but no fan spinning ( because missing p5vs3 and pp5vs0)
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                bios pin voltages before and after doing smc bypass ?
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  @hackintoshmalang please open another topic for a different issue. Check if PM_SLP_S4_L is present in the meantime.
                  • jheunne
                    a1278 820-2936a fan spin green light only help
                    by jheunne
                    hi there i have a macbook pro a1278 board 820-2936a no boot no dispaly only fan spin and green light. i seen some corroision on top starting to u4900 to u3890 i manage to clean it but still no luck to boot. i figure out that in pp15v t29 there is no available out voltage it shows only 0.6 volts only...
                    10-24-2024, 04:19 AM
                  • Arshad alam4659
                    a1278 no green light
                    by Arshad alam4659
                    i have a a1278 820-3115-b with no green light some measure volt
                    PPBUS_G3H=12v
                    PP3V42_G3H=3.43v
                    SMC_BC_ACOK=3v
                    SMC_BC_ACOK_VCC=3.4v
                    SYS_ONEWIRE=3.46v
                    ADAPTER_SENSE=3.42v
                    someone help i try with original charger
                    09-26-2024, 08:21 AM
                  • MOSSEP
                    Monitor Audio RSW12 - Green light, but no sound
                    by MOSSEP
                    Hi
                    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                    I have already tried replacing all of the...
                    01-26-2025, 08:33 AM
                  • MOSSEP
                    Monitor Audio RSW12 - Green light but no audio
                    by MOSSEP
                    Hi
                    01-26-2025, 08:18 AM
                  • lcdcaps1
                    820-2610-A Sys onewire help, no green light. Please help from the gurus
                    by lcdcaps1
                    Hi
                    I have an 820-2610-A motherboard that has no green light.
                    I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                    From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                    The sys onewire circuit on this model and others is more involved
                    I was hoping if anyone knows about this and how it works, can reply and let me know
                    I know this is an old model but I am sure there are people who still works on these or knows about them
                    I get 1.1v on the C7771 capacitor and will replace...
                    11-06-2023, 01:28 PM
