HP 14, LA-A994P, charging light, power led on for 1 second when power button pressed
  • iplaypty
    • Aug 2017
    • 47
    • FLORIDA
    I have a HP 14, motherboard model LA-A994P. When I plug the charger there is charging light present. When I try to turn in on, the power LED turn on then turn off in about 1 second and stay off.
    I did check the voltages in PU301 (IC RT8243AZQW page 37 of schematic), 3.28v and 4.58v (picture attached)
    No voltages in @PJ302 (should be +3valw) and @PJ303 (should be +5valw) in page 37 of schematics.
    What else should I check, how do I do it?
    is PU301 ok with 4.58v?
    Thanks in advance.
    Mario
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: HP 14, LA-A994P, charging light, power led on for 1 second when power button pres
    Measure the resistance to ground on PJ302, 303. Take a good Picture for the area of Power socket and post with the cord connected, specially PD1, PD2, PD3. Measure voltages at U44 pins 75, 110, 112.
    • iplaypty
      • Aug 2017
      • 47
      • FLORIDA
      Diode Mode: PJ302 = 0.783v, PJ303 = 0.985v
      Resistance Mode: PJ302 = 16.41 Kilo Ohms, PJ303 = 31.2 Kilo Ohms
      U44: pin 75 = 0v, pin 110 = 3.27v, pin 112 = 0v
      • tibd
        • Oct 2014
        • 189
        • Sweden
        Check for shortage at ADP_ID, at TVS diodes PD2 and PD3, at the same area check pc5 and pc6
        • tibd
          • Oct 2014
          • 189
          • Sweden
          Is the PSU original?
          • iplaypty
            • Aug 2017
            • 47
            • FLORIDA
            yes, but not in good condition. I am using another charger, with this new charger i get 0.677v at U44 pin 75, 3.27v pin 110, 0v pin 112
            • iplaypty
              • Aug 2017
              • 47
              • FLORIDA
              ADP_ID is not short to ground, PD2 is not short to ground. I cannot locate PD3, PC5, PC6.
              actually the motherboard is LA-A995P, but the only schematic I could get is LA-A994P.
              • tibd
                • Oct 2014
                • 189
                • Sweden
                PD3 can come in a smal package (0402) TVS diode, usually Close to the Power connector. Bios reprogrammed?.
                • iplaypty
                  • Aug 2017
                  • 47
                  • FLORIDA
                  I think those are the caps. Looks fine.
                  • iplaypty
                    • Aug 2017
                    • 47
                    • FLORIDA
                    I did not reprogram the BIOS.
                    Does it look like a corrupted BIOS?
                    • iplaypty
                      • Aug 2017
                      • 47
                      • FLORIDA
                      Finally found it, but it's empty.
                      Someone else tried to fix this laptop before. Is that missing?
                      • tibd
                        • Oct 2014
                        • 189
                        • Sweden
                        I don't think PD3 went missing of someone else picking on this board. Seems legit from manufacturer. It main function is to supress transient voltage from getting to the board, they usually go bad in these models and can be left uninstalled or changed. So thats not the problem there. I'll see if i have the LA-A995P at my Collections, that way easier to troubleshoot.
                        Corrupt bios have a wide range of symtoms, but Worth trying.
                        Do u have any oscilloscope to see if EC_ON is produced for a split of a sec, otherwise u can attach LED diode throug resistor to that pin for testing.
                        • tibd
                          • Oct 2014
                          • 189
                          • Sweden
                          u can try injecting 3v at pin 13 PU301 after removing pr315 and see what happens while trying to start laptop.
                          couldn't find any schematics neither, might be difficult to trace stufs or the Components are the same. I can se the layout is fairly different from ur pics compaired to la-a994p.
                          • iplaypty
                            • Aug 2017
                            • 47
                            • FLORIDA
                            I have tried to turn it on, and it turns on for 1 sec.
                            There is no +3valw on @PJ302 when is off, but +3valw is present when I turn it on (for 1 sec)
                            There is no +5valw on @PJ303 when is off, but +5valw is present when I turn it on (for 1 sec)
                            • iplaypty
                              • Aug 2017
                              • 47
                              • FLORIDA
                              I do not have an oscilloscope, but I was able to test with the multimeter.
                              When I press the power button i get 3.27v on PIN 13 PU301. 3.27v for 1-2secs then 0v.
                              • tibd
                                • Oct 2014
                                • 189
                                • Sweden
                                No need to try injecting 3 v at pin13 PU301. There is something causing U44 to reset the EC_ON signal. Without proper schematics this might be no solve but worth trying. It might be a very small cap shorted on a low Power rail and not heating causing the reset.
                                U said that someone else tried to fix it, is that a statment or a guess? if someone did try then i would defintely start by searching for a proper BIOS for the specific board and reprogram.
                                Do u have a battery with the laptop? measure EC_ON while battery attached + RAM.
                                Can you include a crisp and zoomable Picture for both sides of the board in HD? need to look at some Components and see if the given schematics fits for further troubleshooting. an HD Picture for the KB connector and surrounding.
                                • iplaypty
                                  • Aug 2017
                                  • 47
                                  • FLORIDA
                                  Someone else tried to fix the laptop, but that person doesn't do board component level repair.
                                  I do not have a BIOS programmer device. I do not have a camera for HD picture, but I will upload the best photo I can take.
                                  I do have a regulated power supply, not sure where to inject amps to find the shorted cap.
                                  • iplaypty
                                    • Aug 2017
                                    • 47
                                    • FLORIDA
                                    I took some pictures with my phone.
                                    The owner of the laptop told me that he was using the computer, then it suddenly turned off.
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3609
                                      • slovakia
                                      If it is starting, u have 3.3 ALW so u must have EC_ON
                                      measure short to ground and voltage when it is starting on all big grey coils and capacitors
                                      find short to ground, low voltage /overload/, no voltage /not work/ or bigger voltage /burn/
                                      @ in schematic means that is not used
                                      • tibd
                                        • Oct 2014
                                        • 189
                                        • Sweden
                                        The only voltage he has is 3v ACIN and 3VLP, the EC_ON is being generaterd for a split of a second giving EN at pin 13 PU301 which generats 3 and 5VALW. the the KB is reseting EC_ON.
                                        @ iplaypty
                                        Measure voltage at ADPIN at PR1 (BOTH sides of the resistor). Resistance of PR7.
                                        Does the CPU warm up a bit when connected?
                                        • Andreasbest
                                          Dell Latitude 7410 dead and amber light as long power button is pressed.
                                          by Andreasbest
                                          Hello.
                                          I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
                                          Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
                                          Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
                                          Fact #3 i tried hard reset with cmos/main battery disconnected and power...
                                          12-21-2024, 02:02 PM
                                        • zwect
                                          Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                                          by zwect
                                          I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                                          Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                                          Here is the original BIOS dump from the 25R256JVEN chip.
                                          09-11-2024, 05:54 PM
                                          Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                          by sam_sam_sam
                                          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                          I also have back when Light of America had these light bulbs available for yard lights
                                          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                          While the Lithonia lighting fixture has all most certain bulb failure
                                          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                          I have only had this light fixture for not more than a year if it...
                                          07-02-2023, 03:45 PM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:10 PM
