Hi friend this laptop have a strange problem at press power button the laptop power on for one second the fan work and the wifi indicato on in orange color and immediatly power off and one second later qutomatically power on and power off continually. I have see the mb and not see any componet damage fisically, waths append ? thanks
hp g62 010170100-600-g power on and immediatly power off
Tags: None
Re: hp g62 010170100-600-g power on and immediatly power off
Hello there, you should reprogram the bios chip 1st, cause it is a common fault on these kinds of laptops. That being said there is a chance that the machine is in a protected state due to overheating and the north bridge might as well be fried.
And try to be sure of the Charger you are using, it has to be an hp 90W psu, the smart pin thing is a real pain in the ***. -
I thought it was bios but in the forum I did not find any dump, do you have one? when this happened the pc issued a distorted sound and got stuck, when then I restarted it did this phenomenonComment
Yes, nothing chip or component are hot, the laptop power on and off continually when the problem appeared the handset was running properly, I unplugged the power cord, the battery was plugged in and the screen disinked and the buzzer sounded very loud. when I turned off the laptop and restarted it started to do this. Help :-(Comment
it does not seem a Bios issue. it is probably something like a power problem. but I am not sure. the only way is to check mainboard components according to schematics. first check the AC adapter as recommended in post 2.Comment
MB Code??? Does it has ATI Graphics??Comment
This is the mb code 010170100-600-g I have changed the power adaptor whit a brand new but nothing have changed. How part of the mb I can check ? It's possible say me a chip probably causes this problem ? ThanksComment
Search for HP650 or HP 2000 and you will get many bios dumps in this forum. Your mb is same.Comment
Hi friends I have measure at coil pin and measure 0V if I take positive from dc jack and negative on coil I measure 19V at laptop switch off and 16,22V on one coil and 14,2 on second coil at laptop switch onLast edited by magnetepazzo; 11-23-2017, 03:02 PM.Comment
I do not know about this method of measurement.
standard method: put black probe on GND and red probe on the point which you want to measure.
If you do this measurement, important faults may be discovered.
Assuming you measured correctly, 16,22v and 14,2v are bad voltages.
please report like this: L1021 = 16v.Last edited by caspian; 11-23-2017, 04:01 PM.Comment
if you have pulse on one side, measure on the other side. Thats normal. All bigger coils are part of switching power mode power supply. Try the board without RAM. Then if the board not switch off immediately, try it with other memory modul.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
