macbook (A1286) horizontal lines
  • basic
    • Oct 2017
    • 229
    • 86357289244
    anyone has this problem ..
    model A1286 core i7 intel graphics ,so for that i am wondering coz has intel graphics and i have this problem
    is problem GPU or Lcd panel
    best regards
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: macbook (A1286) horizontal lines
    A fixed line is panel's problem or cable's problem. If it changes position, it can also be GPU's fault. Panel/cable problem is much more probable.
    • basic
      • Oct 2017
      • 229
      • 86357289244
      i see horizontal lines on logo and stucks on logo wont boot ..
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        If it does not boot, the operating system or the mainboard have got problems. It can be GPU too.
        • piernov
          • Jan 2016
          • 4439
          • France
          If this is an AMD GPU then this is the problem.
          A1286 corresponds to many different machines so we cannot know for now.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            "core i7 intel graphics"
            • Ihandyrepair
              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
              by Ihandyrepair
              Hi guys
              I just started fixing 4k TV few months ago. so I am still learning a lot
              I got this tv from friend complaint is ghosting or horizontal lines on image.
              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
              then it started to show the ghosting white image.
              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
              it has 3 thin small boards at the bottom of the...
              12-05-2022, 04:18 PM
            • psdavid65
              Macbook Air A1466 820-3437-B Booting Problem
              by psdavid65
              I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
              06-20-2024, 12:27 AM
            • Skrndelj
              Apple Macbook Air M1 A2337 Trackpad problem
              by Skrndelj
              Hello all,
              I am repairing a Macbook A2337 and i have a problem
              The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
              When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
              I inspected the whole board and everything seems fine.
              Can anyone help me as i didn't fiddle with trackpad...
              06-11-2024, 04:26 AM
            • x_orange90_x
              Samsung UN46C8000XFXZA Horizontal lines
              by x_orange90_x
              I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
              I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
              07-15-2023, 05:06 AM
            • sdogs
              Macbook Air 2020 A2179 820-01958 battery problem?
              by sdogs
              I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
              After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
              I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
              Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
              02-08-2024, 08:00 AM
