replacemen- compatible- of mosfet AON7200
  • nabi
    • Sep 2017
    • 15
    • algeria
    i need equivalent for mosfet AON7200 in samsung NP270E5V
    i try with AP9402GYT but no result
    thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: replacemen- compatible- of mosfet AON7200
    Si4456DY (N-Channel 40-V MOSFET)-You can try this mosfet. Though AON7200 is 30v mosfet and 4456 is 40v, it shouldnt matter as the replacement is of higher capacity. Chech datasheets of both to be sure. But i'm rather hopeful, this will work.
    • tofik
      MOSFET equivalent K8A60DA
      by tofik
      Hello guys,
      I have a shorted MOSFET K8A60DA with the following characteristics:
      Type Designator: TK8A60DA
      Marking Code: K8A60DA
      Type of Transistor: MOSFET
      Type of Control Channel: N -Channel
      Maximum Power Dissipation (Pd): 45 W
      Maximum Drain-Source Voltage |Vds|: 600 V
      Maximum Gate-Source Voltage |Vgs|: 30 V
      Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
      Maximum Drain Current |Id|: 7.5 A
      Maximum Junction Temperature (Tj): 150 °C
      Total Gate Charge (Qg): 20 nC
      Rise Time (tr): 25 nS
      Drain-Source
      07-19-2023, 05:18 AM
    • dreico33
      AON7403 Mosfet Equivalent
      by dreico33
      Hellow guys,
      I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
      Thank you very much.
      11-16-2024, 09:28 AM
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
    • mohamed mm
      looking for equivalent mosfet for (IR3598MTRPBF)
      by mohamed mm
      I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
      it's for motherboard ram voltage.
      I hope someone can help me.
      Thank you.
      11-01-2023, 07:28 AM
    • jackx
      equivalent MOSFET 4C09B
      by jackx
      hello brother
      i need equivalent MOSFET 4C09B
      05-27-2024, 03:41 PM
