samsung rc410 broken charging port replacement
  • String2016
    • Nov 2015
    • 2238
    • philippines
    hi friends i need help on this i have a samsung laptop Rc410 with broken charging port i need to replace but i dont have spare with the same charging port i have here samsung charging port also but it is from netbook different pins can i convert this to replace the rc410 charging port?I have attached the image of the two the upper one is broken on the bottom is available replacement from scrapboard. please help
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: samsung rc410 broken charging port replacement
    Here is a picture and a link to buy a replacement . It's cheap and better than modifying , which may bring unusual results ..
    https://www.amazon.co.uk/Power-Charg.../dp/B00UYMRUW0
    • String2016
      • Nov 2015
      • 2238
      • philippines
      thanks for the response jiroy if i order online it takes time to deliver i have spare scrapboard samsung but different model its from notebook sori i forgot to attached the image i need a advise if can i use this to convert the dc jack?
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        It look the same , and If the pins placement are the same , it's usually compatible . You can always test with a multimeter , comparing the two , just to be on the safe side .
        • String2016
          • Nov 2015
          • 2238
          • philippines
          and here is on the other side. is this possible to replace?
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            From this side , it look the same too . If you want a 100% confirmation , put the part number of the used Samsung board ..
            • String2016
              • Nov 2015
              • 2238
              • philippines
              the board code on the broken dc jack is model:jinmao-L rev 1.0 (101125) and the notebook for possible replacement board code is Eric-ve-r rev 1.0
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                It's a match , if my eyes are still good today lol :
                https://ar.aliexpress.com/store/prod...023741127.html
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  thanks jiroy ill try to replaced with this
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    Good luck ..
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      If you are replacing the jack marked broken then the three pins on the back are not the same spacing as the suggestion in post #8
                      Just search for RC410 on Aliexpress and find plenty.
                      https://ar.aliexpress.com/item/NEW-P...667696446.html
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        @diff they are plenty online but the problem is almost a month delivery the client in a hurry
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          They usually are, but my point was the part in post #8 is wrong.
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            you are right diff i tried changing with above post replacement charging port when i plugged in the charger ther is no 19v on dc maybe i need to order the right one charging port i attached the image after i replaced the charging port
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              It's the top pin of the three in your second photo that should have voltage.
                              I can't see the first photo properly as it's blurry but it looks like you might have added a wire ?
                              • jiroy
                                • Jun 2016
                                • 2416
                                • Lebanon
                                I took it According to this compatibility list , it's the same pins placement
                                https://www.facebook.com/permalink.p...25055614188340
                                Maybe the used one was bad or overheated .
                                • String2016
                                  • Nov 2015
                                  • 2238
                                  • philippines
                                  yes i put a wire to connet to the third pin because cannot reach the third pin i have no voltages on three sides here is the clear image on the top
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Wow fb as a source :p that list is clearly wrong as the photos show.
                                    There are several different types of socket for the Samsung laptops. Similar but different pin spacings. I have one of each in stock.
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      is there a chance to work this replacement dc jack connector?please help
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        I'd remove the socket from the motherboard and verify which pin has voltage on it. Perhaps you've put the link wire on the wrong one.
                                          09-07-2024, 05:50 AM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • thesame
                                          Lenovo TB-X605F fake charging after charging connector replacement.
                                          by thesame
                                          Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
                                          04-03-2024, 03:14 AM
                                          09-06-2024, 11:40 PM
