hi friends i need help on this i have a samsung laptop Rc410 with broken charging port i need to replace but i dont have spare with the same charging port i have here samsung charging port also but it is from netbook different pins can i convert this to replace the rc410 charging port?I have attached the image of the two the upper one is broken on the bottom is available replacement from scrapboard. please help
samsung rc410 broken charging port replacement
Tags: None
Re: samsung rc410 broken charging port replacement
Here is a picture and a link to buy a replacement . It's cheap and better than modifying , which may bring unusual results ..
https://www.amazon.co.uk/Power-Charg.../dp/B00UYMRUW0 -
thanks for the response jiroy if i order online it takes time to deliver i have spare scrapboard samsung but different model its from notebook sori i forgot to attached the image i need a advise if can i use this to convert the dc jack?Comment
It look the same , and If the pins placement are the same , it's usually compatible . You can always test with a multimeter , comparing the two , just to be on the safe side .Comment
the board code on the broken dc jack is model:jinmao-L rev 1.0 (101125) and the notebook for possible replacement board code is Eric-ve-r rev 1.0Comment
It's a match , if my eyes are still good today lol :
https://ar.aliexpress.com/store/prod...023741127.htmlComment
If you are replacing the jack marked broken then the three pins on the back are not the same spacing as the suggestion in post #8
Just search for RC410 on Aliexpress and find plenty.
https://ar.aliexpress.com/item/NEW-P...667696446.htmlComment
@diff they are plenty online but the problem is almost a month delivery the client in a hurryComment
you are right diff i tried changing with above post replacement charging port when i plugged in the charger ther is no 19v on dc maybe i need to order the right one charging port i attached the image after i replaced the charging portComment
It's the top pin of the three in your second photo that should have voltage.
I can't see the first photo properly as it's blurry but it looks like you might have added a wire ?Comment
I took it According to this compatibility list , it's the same pins placement
https://www.facebook.com/permalink.p...25055614188340
Maybe the used one was bad or overheated .Comment
Wow fb as a source :p that list is clearly wrong as the photos show.I took it According to this compatibility list , it's the same pins placement
There are several different types of socket for the Samsung laptops. Similar but different pin spacings. I have one of each in stock.Comment
is there a chance to work this replacement dc jack connector?please helpComment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM -
by thesameHy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
