HP Pavillion 23" AIO won't power up, Motherboared PWR LED flashes briefly!
  • pclaptop
    • 13
    • US
    I'm hoping someone else has had this problem or has seen/heard of it before.
    I have an HP Pavilion 23-H TouchSmart All-In-One computer that won't power up. Initially I believe it took a power surge and cooked the mother board and power supply.
    I have replaced, Motherboard, CPU, and Ram, CMOS battery and the power supply(with a genuine HP OEM unit).
    Whereas before when I first looked at this unit there was nothing happening, no lights, fans, boot up, NOTHING.
    VOM confirmed power supply was dead.
    I installed all of the above new replacement components and the ONLY sign of life is the onboard motherboard PWR LED briefly flashes. I'm assuming as in other motherboards this light needs to STAY lit. IT DOES NOT.
    This type of AIO computer was very problematic and was discontinued after 2yrs. One of the many problems was a faulty power on switch mounted on the upper left outside frame. But again VOM says micro switch is functioning correctly on this unit, but without motherboard power (as indicated by PWR LED inside yellow circle on attached pic) how can it boot up?
  • pclaptop
    • 13
    • US
    Re: HP Pavillion 23" AIO won't power up, Motherboared PWR LED flashes briefly!
    To all who maybe able to help, the one thing that defeats the "bad/defective POWER On/Off switch" (as the cause) is that with that scenario, the PWR LED next to the power in jack is LIT.
    For some reason with all NEW components in this HP23 Touchsmart, that same PWR LED only flashes momentarily and then goes out.
    Is it safe/correct to assume that if the PWR LED is NOT lit, there is no power to the motherboard? So even if the bad/defective POWER on/off switch was functioning OK, it wouldn't have an energized motherboard to turn on?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      You got a defective mainboard.
      A working TV? How boring!
      • pclaptop
        • 13
        • US
        th3 un1qu3, it's a brand new motherboard, not that it is impossible for it to be bad, just highly unlikely.
        What about the power supply(which is new too)? It is an HP OEM, bad switching power supply design?
        btw thanks for reply
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • dicky96
          Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
          by dicky96
          Hi guys
          I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
          If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
          If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
          03-24-2023, 06:33 AM
        • Gjackson
          Air-conditioning unit power supply failing to power up
          by Gjackson
          Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
          01-08-2022, 09:24 AM
