my s3 mini wont turn on
  • mista
    • Apr 2015
    • 92
    • belgium
    hi friend my s3 mini wont turn on any solution ?
    do you have some schematic ? my battery is 3.2v is it ok to turn on the phone?
    thanx
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: my s3 mini wont turn on
    3.2V is not enough, you need at least 3.4V IIRC. Nominal voltage is 3.8V and a fully charged battery should be a bit above 4V.
    • mista
      • Apr 2015
      • 92
      • belgium
      hi ok thanx a lot for confirmation so how can i charge it by pass to see if the problem is the charger port or the battery it self because i change charger but same problem
      • xfce
        • Aug 2017
        • 18
        hello,
        the easiest way is to check if you get ~4.2v(while charging) on the pins where battery is connecting(for that you need multimeter) . If you get it, means that the route from charging port to the battery is ok. Battery itself should not go above 3.7v (if on the battery is written 3.7v) even when is fully charged. More then that means battery is not good.
        • mista
          • Apr 2015
          • 92
          • belgium
          hi and thanx for reply but how can i check charging by multimeter un put two wires from multimeter and charging by usb port?
          regards
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            easiest way is to plug it into a usb monitor.
            battery that low may be in pre charge.about 50ma.
            there will be no signs of life till it goes to full charging current.
            then it will go to startup then battery level.
            if you dont see any current draw on the monitor look at the usb jack.
            i replace them all the time.
            full charge voltage is 4.35v
            http://www.ebay.com/itm/DROK-USB-2-0...3520548http://
            • mista
              • Apr 2015
              • 92
              • belgium
              hi friend thanx a lot for your help your link is not working
              what do you call usb monitor
              sorry i m beginner if you have some picture or video to understand
              thanx a lot for help
              • diif
                • Feb 2014
                • 6978
                • England
                Something like this.
                http://www.ebay.co.uk/itm/LCD-USB-De...-/292076965244
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  this is the one i have got
                  https://www.youtube.com/watch?v=oANNq7Q83f4
                  • mista
                    • Apr 2015
                    • 92
                    • belgium
                    hi guys thanx a lot for sharing i understood now for checking
                    • mista
                      • Apr 2015
                      • 92
                      • belgium
                      i im waiting for usb monitor and i will try the test ...
                      to be continued
                      regards
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
                      • nikolayu
                        Dell Latitude 5420 wont turn on when charger is connected
                        by nikolayu
                        I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
                        Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
                        The same thing if I connect to other USB C port.
                        Charger is OEM
                        03-13-2024, 12:34 PM
                      • DanPoka
                        Allview phone charger A248-NB2-501000
                        by DanPoka
                        I've got an old phone charger which cannot hold voltage, it goes from 5V to 4V the fault only seems to happen when charger has been on for a while e.g. when warm. Fault happens when high current or low current is being drawn from charger. I've checked capacitors for capacity and ESR and I think they are still good, I've even replaced a cap to get better ESR. Fault still happens it goes slowly from 5V to 4V then interrupts power and restarts. Because it performs on high current (0.67A) and low current (20 mA) the same way I'm guessing it's not the caps but more likely the switching IC. However...
                        02-22-2024, 04:41 AM
                        HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                        This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-12-2024, 03:36 PM
                        HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                        This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                        09-12-2024, 02:20 PM
