Asus g751jy no voltage on 3V3main and aon net
    Hello to all, here is the situation....the laptop is turning on, no picture,has no voltage on 3v3 main and 3v3 aon net...i look at the boardview (attached) and found that voltage should come from 12vsus net, but for some reason it is not. First i found that the ec chip 25x40clsnig is not receiving any power, the voltage reading was zero or 0,1 v on aon net.
    I was finally able to find area where the power problem is but i dont understand why and which part is responsible...please help
    So first picture, this is ec chip and nowhere there is voltage relating ground, on aon net 0.09v.
    (Image hosting links dead)
    I was searching through the boardview, checking how 3v3 main and aon nets are connected to the rest of the board and on the next picture i found that somewhere here is the problem. That resistor r7124 is not transfering the voltage from +12vsus net on DGPU power main.
    I was not sure about that so i borrow exactly the same laptop from my friend and i was right. His readings from his motherboard are ok and shown on the next picture.
    I am not sure now what is going on. I checked resistence of that resistor (while on board) and it is reading 100k ohm. can anybody look at the boardview and picture please and suggest what to do next.
    Thank you all!
    Re: Asus g751jy no voltage on 3V3main and aon net
    The stuff you're looking at is for the dedicated GPU. You'll need the main BIOS to run for the GPU to be turned on (if I'm not mistaken).
    Also U9402 is the VGA BIOS.
    Do you have +VCORE and CPU_RST#?
      on +vcore i have 1.79v, and arround 23 ohms relating ground (while not working)
      on cpu_rst i have 1.09v
      Main BIOS i already tried to reprogram with some bios dump i found on the internet but its the same thing, no power to vga bios.
        Piernov?... anybody?
          Good day, in my case it turned out to be faulty FERRITE BEAD L7133, located near the gpu flash - U9402.
            EDIT: Image hosting links dead
              https://drive.google.com/drive/folde...vZ?usp=sharing
                link is dead , can u upload again ? Thx
