What controlls backlight intensity K72DR
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    Hello, can any one tell me how backlight intensity is being controlled?
    I have an Asus K72DR (Rev 3) laptop board which behaves as following:
    100%-70% Normal dimming per 10% and Backlight is on
    60%-0% Nothing visible on screen, backlight is turned off
    Same happens on battery or charger.
    Screen was replaced as well, same thing happens.
    Ive found an boardview of this board but I can not understand anything from it nor find the schematic anywhere.
    The original problem was with the chipset that got reballed and now the laptop works (But with backlight problem).
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    Re: What controlls backlight intensity K72DR
    EC Controls the backlight via PWM signal, downgrading the BIOS fixed the issue here.
    • bachir2004
      • Feb 2015
      • 439
      • maroc
      reinstalling video card drivers can resolve this.
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
      • canadaboy25
        LG Flatron 24EN33TA No Backlight When Cold
        by canadaboy25
        I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
        I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
        03-07-2023, 12:23 AM
