HP EliteBook 2570p turns off after 5 seconds
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 332
    • D12
    I got this broken HP EliteBook 2570p when I turn it On laptop shows no picture and fan keeps spinning at max. I disassemble it and found one mosfet burned, don't know what that mosfet is and his purpose but I think he is responsible for laptop to not turn On. I attached pictures so if someone knows what that mosfet is, and if he is worth replacing or should I replace the whole motherboard, and any other info. like that would be cool, thanks.
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: HP EliteBook 2570p turns off after 5 seconds
    I think is n channel mosfet change mosfet and try.
    • Thermaltake
      Brain badcap
      • Aug 2015
      • 332
      • D12
      What is that n channel mosfet for ?
      What I think happend is user from USA (laptop is from USA) use cable that came with adapter and have 3 pin USA power connector that supports 10A 125V ~ (it's labeled on it) and try to use it here in EU with EU adapter and that burn the mosfet, thats what I think but I could be wrong that's just my intuition.
      Could it be it's only that mosfet or maybe he burned something along with himself or short, but it's not showing any burns ?
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 332
        • D12
        Can someone give me sheme for that motherboard PN is 685404-601.
        I don't know what n mosfet I need to buy to repair this cause mine is all black, can't read the number from it.
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 332
          • D12
          anyone please help ?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            You can try putting up any mosfet(around cpu socket) from hp motherboard . Its not going to harm you. Try powering with lab psu,if available.
            • BlueMidnight
              • Jan 2015
              • 489
              The power supply itself should support 100-240V. The rating written on the cord just identifies it as a cable for the US market. To pass regulations, I believe the wire needs to be rated at least 300V RMS. There might be another rating stamped into the cord but harder to see. In any case, this wouldn't have anything to do with the problem.
              I could not find a (free) schematic for this model. However, I was able to find a couple cousins. You will find the circuit with the bad MOSFET on page 9 in both.
              By the way, for those who are curious... just by looking at the board itself, you can see the 2 MOSFETs and the coil/inductor they connect to. This is the hallmark of a synchronous buck converter circuit. The larger MOSFET is always the low-side one (connected between the output and ground), because that one spends a much longer time turned on. The smaller one (the one destroyed on your board) is the high-side MOSFET (connected between the output and the supply voltage). On many boards they just use ones that are the same size though. In that case, you just have to find out what each is connected to.
              Q6300 is indeed an N-Channel MOSFET. The schematics show a FDMC8884, but that's probably not what was on this actual board. There are many other ones that will work too. It should be quite easy to find a donor board to steal one from. If you want to know which part they actually used on your board, just look at the other buck converter circuits. They probably all/mostly use the same high-side MOSFET.
              The fact that the MOSFET burned up in that way means there is a chance that the full supply voltage was connected to the 1.05V output rail. That could have damaged a number of things, including the CPU. You can try replacing the MOSFET and see if it helps. But don't waste too much time on it.
              In some cases, the controller chip is damaged and will just keep frying the high-side MOSFET. So, you might have to replace it (U6300) and the MOSFET at the same time.
              • Thermaltake
                Brain badcap
                • Aug 2015
                • 332
                • D12
                Thanks for the help and explanation. I think I will just buy a new board and sell this one as it is like that, too much can go wrong because of one mosfet. I somehow doubt it's only that mosfet that failed in this case.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  You give up too easily.
                  A working TV? How boring!
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 332
                    • D12
                    Hehe it's not that, I bought this laptop at super price so there is still a lot of room to buy a new motherboard instead of having sex with this one. I just don't have much time lately to check whats wrong with that board, so it's time saver to do it like this.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Sometimes i can relate to that - i have a 55" LG TV with backlights on but no picture i have wanted to fix for almost 1 year now, but since the panel looks good i'll likely just bite the bullet and buy a replacement main like i did for my 37".
                      The only reason i haven't done that until now is that it's pretty expensive (around 100 Euro) and hard to sell on if the panel turns out to have issues, but since i moved in with my girlfriend there is a big white wall in our bedroom, opposite to the bed, that just screams "big TV goes here". I haven't bothered to put up the 37" because it would be too small for the distance, but then i would get used to it and never fix the big one.
                      Tinkering with stuff is great when you have a lot of time on your hands and no deadlines, but life eventually gets in the way. That's not a bad thing, though.
                      • Thermaltake
                        Brain badcap
                        • Aug 2015
                        • 332
                        • D12
                        Hehe
                        Exactly every word you said.
                        • mikemike096
                          • Dec 2017
                          • philippines
                          Good day, Is it possible for a blown/missing C6502 and C6503 and the same mosfet blown to be related ?
                          Had this happen to my 2570p a while ago as i plugged in its AC adapter as the battery was fully drained then turned it on initially nothing happened so i checked if i connected the AC adapter properly and it was so i tried turning it on again and it made its usual boot actions (100% fan, LCD blacks out, fan subsides) but then turned off at the point the boot screen was to be displayed on and was greeted instead by a wafting burning smell coming from the laptop so i yanked the battery and wall adapter out. Came across this site and sure enough a peek through the case has a burned mosfet but also mounting pads C6502 and 6503 looking like its missing a capacitor.
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            take a photo of those pads and upload it here.
                            • mikemike096
                              • Dec 2017
                              • philippines
                              I apologize for the picture i haven't taken it apart yet.
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3599
                                • slovakia
                                offcourse when burn capacitor makes short it can blow mosfet
                                • caspian
                                  • Oct 2015
                                  • 1591
                                  • Laptop
                                  this photo does not have enough quality. you can compare it with internet photos of the mainboard to see whether there exist those two capacitors or not.
                                    HP EliteBook 2570p Notebook 2000 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook 2570p Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 2570p boardview and 2570p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP EliteBook 2570p...
                                    09-06-2024, 05:27 AM
                                  • zklgfs
                                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                    by zklgfs
                                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                    08-11-2025, 02:14 PM
                                  • twonk9098
                                    Lenovo Legion 5 high fan spin turns off after 34 seconds
                                    by twonk9098
                                    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                    I have tried a few new bios but exactly...
                                    07-14-2024, 11:19 AM
                                  • Rick_1234
                                    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                    by Rick_1234
                                    Good evening, gentlemen.
                                    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                    https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                    Things I tried
                                    - Bought a new AC adapter thinking that was the problem but the problem...
                                    06-22-2024, 04:44 PM
