Dell Inspiron 5110 No display on led but getting external display
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Hi friends
    I have problem with dell inspiron 5110 model.
    Am getting external display and no display on led.
    Laptop screen is working fine check with another laptop
    problem with motherboard could you please suggest any troubleshooting
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Dell Inspiron 5110 No display on led but getting external display
    Check LVDS connector for LCD_EN, BLON, LCD_VCC
    • sureshbobby
      • Mar 2015
      • 137
      • India
      Friend thanks reply I have checked cable it's working fine
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        I told you to check the connector on the m/board for its voltages.
        • elektro-nik
          • Mar 2014
          • 8
          • Russia
          There are two versions of this laptop
          On INTEL and AMD platform, Motherboards on INTEL come with NVIDIA and ATI graphics card and without discrete video - UMA
          What is your motherboard ?
          LVDS connector is the same in all versions, measure the voltage as you advised raajkumar
          • sureshbobby
            • Mar 2015
            • 137
            • India
            Thank you
            Mine is Intel without discrete graphics
            and the voltages present is
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              Since you have only Intel discrete graphics and the LED cable is okay , then another probable cause to your trouble is , Some Laptops are equipped with Led HD screens , or many other specifications like True brightness , 3d vision , etc..proprieties specific to those some laptops . Some types of regular screens simply won't operate .
              I suggest you recheck your Laptop by Serial number , tag or model number for a fully compatible screen , or seek the original screen from Dell .
              Another probable cause is , you shorted a component while changing the screen , as you didn't remove the power or the battery . In that case , you need to check visually for any damaged or burnt small transistors or resistors around the inlet cable onboard .
              • sureshbobby
                • Mar 2015
                • 137
                • India
                Hi friend
                This is the original display which is working with the other laptop as well. The same screen worked flawlessly before. but all of sudden it happened.
                So there might me a problem in the motherboard. Am here to troubleshoot with our techies help.
                Much appreciated if am solved this problem.
                Thank you
                • raajkumar
                  • Mar 2015
                  • 354
                  • Srilanka
                  Thank you
                  What about LCDVDD is Pin 28,29,30. LCDVDD should be 3.3V. If not available the screen will not show anything.
                  • sureshbobby
                    • Mar 2015
                    • 137
                    • India
                    No voltage at pin 28.29.30
                    • raajkumar
                      • Mar 2015
                      • 354
                      • Srilanka
                      So i think there was a chip with 5 pins near to LVDS connector on motherboard. It is looking 2 pins one side 3 pins other side. You can put a jumper between pin no. 3 to pin no 4. then you can switch on and check it. you can see pinout of that chip on my attached picture.
                      • sureshbobby
                        • Mar 2015
                        • 137
                        • India
                        Friend Thank you Man.
                        Done it. i got display. I have old same board can i replace it or can i make jumpler
                        • raajkumar
                          • Mar 2015
                          • 354
                          • Srilanka
                          You can replace it.
                          • elektro-nik
                            • Mar 2014
                            • 8
                            • Russia
                            For quick checking connect 27 pin and 28
                            • lazybigyan
                              • Mar 2017
                              • 81
                              • Nepal
                              I have dell 5110 with discrete which is converted into the uma. The issue is deam display. In LVDS cable 1, 2, 3 has 19v which is ok for blow for LED that I think. HALL 1 connector pin no 2 and 4 has also 3.2v. So help me for solution, Please.
                              Thank you.
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3628
                                • slovakia
                                Thank you.
                                check for 3.3V - BK_ON signal and 3.3V BL_PWM signal
