Hp DV7-6151EF only turns ON every 30 atempts
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Never see something like this.
    Oncee i get it running it works perfectly, can reboot withou a problem.
    Once i turn it Off, here the problem:
    When i press the On Switch, there is no led or any reaction, when i have a battery inserted, and running only on battery, when i turn it of, the led near the power imput connector it stays ON (WIERD)
    Model : Hp DV7-6151EF
    Any Clues Guys ?
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Hp DV7-6151EF only turns ON every 30 atempts
    may be static electricity.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      It makes the same wierd sympton on the owners house and on my local ?
      Can you develop ?
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        If the laptop turns on after a number of pressing the power button, it may be due to static electricity.
        it is just a possibility.
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          Check cmos battery check.
          Try running the laptop with cmos battery out ?
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            Actual Cmos Battery is reading 3,02V, i have replaced with another reading 3,01 and Laptop is now turning On Normaly.
            Very Wierd.
            Anyway, thanks guys for your Tips.
            • Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
              by Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
              03-15-2024, 09:37 AM
            • www
              LG L192WS-BN backlight turns off after 1 second
              by www
              I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
              I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
              03-24-2024, 05:26 PM
            • andrhouseolly
              Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
              by andrhouseolly
              Hi.
              I kindly ask you to help me solve the problem.
              Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
              The board turns on, there is no image.
              Read more. When the power supply is connected, the front panel indicators light up briefly.
              When you press the power button, the button indicator lights up. The board works
              there is no image, there is no matrix initialization, there is no image on HDMI.
              When turned on, the fans do not spin, but when they warm up they start spinning.
              When you turn off the button, the fans spin up to full speed for a short...
              05-11-2024, 03:14 PM
            • Egidio85
              Samsung UE55F8000SZ Turns on and off immediately
              by Egidio85
              good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
              This defect happens continuously, hearing the classic click of the relay every time.
              Power supply board BN44-00636B
              disconnecting the mains and lamps from the power board always causes the same problem.
              Is it normal that without anything connected this power supply turns on and off cyclically?
              any suggestions on what to check?
              thanks in advance
              03-11-2025, 12:45 PM
            • mostachio
              Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
              by mostachio
              Hi Badcaps,
              I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
              TV Details:
              Model # - TH-65DX700Z
              Symptoms:
              The television turns on and displays a picture then makes a clicking sound and turns off.
              I haven't opened it up yet but...
              09-04-2024, 02:32 AM
