Asus g73jh boot "problem"
  • myth77
    • Feb 2017
    • 380
    • Croatia
    The problem is when i start it it shuts down after one second (no screen, only lights, power, keyboard...for a brief moment). Then, when i power it again it works fine..all day..temperatures are ok and everything seems fine...Later, if i shut it down, and start it in couple of minutes it will start ok, with no problems..But, lets say if i waith like one hour then it will shuttdown on first start, and later on second start it will work fine...
    Any ideas?
  • s.m.hosein
    • Jun 2015
    • 23
    • esf
    Re: Asus g73jh boot "problem"
    its seems to be bios issue
    update the version if there is a newer version
    if not program it and i think you will be good to go
    • futadmytro
      Asus g713qm-es94 stuck on boot bios problem
      by futadmytro
      sn^M4NRKD02753616E
      MB- g533-6050a3250201-MB-A03
      Stuck on boot after ROG logo, did not enter to bios
      In flash bios , laprop boot but have video issue
      orig bios...
      06-25-2025, 08:07 AM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • lazaro.089
      Asus Zephyrus M16 / GU603ZW problem
      by lazaro.089
      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
      CPU: Core i9-12900H
      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
      08-26-2025, 06:33 PM
    • trbovan
      Asus GL731GT Boot loop
      by trbovan
      Laptop is a GL731GT with the I7-9750h and GTX1650.
      Full model number is gl731gt-rb71-cb
      Serial: (placeholder for when I get home)
      Board model: G531GT REV. 1.5
      Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
      I assembled and tested anyway. The bios worked, I was able...
      10-04-2023, 07:27 AM
    • dqtech
      Asus X407M Bios Problem (won't boot)
      by dqtech
      Motherboard X407MA REV 2.0
      this laptop have a problem with latest bios version 310...it cannot boot to windows, just stuck at ASUS logo...
      i did flash bios chip with the old bios version 301 and seems okay, but after few second came out notification saying "please restart to update firmware" and after i restart the laptop, system will automatically go to bios and suddenly update bios it self to 310....
      i try to reinstall windows, everything just fine as long im not "check for updates" on windows update....the only problem with the...
      09-19-2022, 01:54 PM
