lenovo, no EC_ON signal
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    hello. my friend bring me board with "two bad tranzistors". I check it and it looks like bad charging chip BQXXXX. So i jump second mossfet on adapter side to have B+ 19V. i have 19V on PJ401, 3.3V on pj404. But dont have EN1 /+3VALW_EN/ from SIO. Do u think SIO is bad?
  • fester
    • May 2017
    • 158
    • Slovakia
    Re: lenovo, no EC_ON signal
    you have PJ401 and PJ404 populated? according to schematic is not (@ sign),bevare of connecting both sides of this jumpers, "second mosfet" is which one?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3577
      • slovakia
      second mosfet is PQ302
      that jumpers is from factory.
      • fester
        • May 2017
        • 158
        • Slovakia
        charging chip communicate over i2c with SIO so if is this chip faulty SIO is not switching ALW power lines imho must not to be bad.change this charging ic first
        • piernov
          • Jan 2016
          • 4435
          • France
          First change charger IC and it should solve your issue, EC needs to communicate with it. Make sure you're using AC power and no battery.
          If it still doesn't work try to flash the IT8586E.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3577
            • slovakia
            i replaced charger chip but nothing changed. still have no EN1 /+3VALW_EN/ from SIO
            dont have programmer for it
            • piernov
              • Jan 2016
              • 4435
              • France
              I cannot understand the EC's initialisation process, but I guess that EC_ON should be high as soon as VSTBY0 is available. So I would say replace EC.
              • fester
                • May 2017
                • 158
                • Slovakia
                Yesterday i had one board with the similar situation,i had power after first mosfet bud second was off..problem was in shorted ceramic capacitor in high side of +3ALW line..this can be also your problem,short somewhere after second mosfet -> over current sensing resistor flow big current -> sio switch it off via charging chip. try inject small voltage(maybe 1V) direct to all ALW power lines and watch the current
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3577
                  • slovakia
                  maybe u have right. after changing BQxxxx i have ACOK and ACPRN. but afteer jumping second mosfet, the short come out
                  im going to inject to vin line
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3577
                    • slovakia
                    ok, i replace the short in PQ312
                    but no change. i make some measures
                    dont have PACIN
                    • fester
                      • May 2017
                      • 158
                      • Slovakia
                      inject direct to 3V alw line,if ok,then try 5V alw line,i dont understand so complex cirquit with all signals like this one :-) on my board i spend maybe 3 hours tracing and meassuring and i gave up because everythig was ok imho...
                      btw ACPRN != PACIN as it goes over PQ309B so you cannot have booth at one time
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3577
                        • slovakia
                        so know anybody which signals must have, so second mosfet switch on
                        as it is P channel, i must have BATT_OUT or PACIN to have negative voltage on secong mosfet gate
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Check voltage on pin ACOK, VCC, SRN, ACDET, REGN of charger IC.
                          ACOK must be low on bq247x7 for PACIN to be high.
                          • khaahk
                            • Dec 2013
                            • 758
                            • Estonia
                            6V at acoff-1 is bad, where it is coming from?
                            it will bring the pacin_g to gnd and you will have 19V at P2-2
                            Adapter is smart and ok?
                            I believe ~380K to gnd from id pin was the value for lenovo.
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3577
                              • slovakia
                              but acok is signal from BQxxx that AC is detected and is ok
                              • piernov
                                • Jan 2016
                                • 4435
                                • France
                                ACOK is active low on bq24737 (see datasheet for bq24707, it's pretty similar) so if you have a voltage on this pin, something is wrong. You should have 0V.
                                You can also check the bq24707 datasheet for the conditions which leads to ACOK activation (involving the pins I listed).
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3577
                                  • slovakia
                                  maybe i have bad datasheet for BQ
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3577
                                    • slovakia
                                    i can not find datasheet for 737.
                                    from datasheet of 707 i must have SRN high like VCC, but i have 0,15V and no short to ground on that signal. acok is 6V and from datasheet it is fault.
                                    Is my BQ bad? /it a new one/
                                    i make some better measurement so chceck it out
                                    • piernov
                                      • Jan 2016
                                      • 4435
                                      • France
                                      According to the datasheet, the conditions are as following:
                                      • voltage on the ACDET pin is above 2.4 V
                                      • voltage on the VCC pin is above UVLO
                                      • voltage on the VCC pin is 245 mV above the voltage on the SRN pin
                                      Voltage on the SRN pin has to be at least 245mV lower than VCC. There is no lower threshold, so I guess 0V is OK too. SRN is connected to the battery line so I think it is never around 19V.
                                      Check the voltage on ACDET, and make sure VCC is around 19V. If they are ok and ACOK is still high, maybe the IC is bad and you can try putting a new one.
                                      • questore
                                        Lenovo Legion 5 missing EC_ON_5V signal (5v_AWL)
                                        by questore
                                        Dear all.
                                        I have a Lenovo Legion 5 that come to me as faulty.
                                        The problem was that Adapter_ID pin was shorted by some liquid... killing the EC (there was a hole in the EC) (therefore 3.3v was shorted)
                                        I have removed shorted EC it and tested that if i short EC_SBM_CK1 to ground, then the BQ24780SRUYR power IC lets 20v pass the first and second mosfet.
                                        Nothing else seems shorted when checking 3V,5V, 1.1V, battery or 1.0v coils, so I have ordered the new EC chip.
                                        I have ordered a preprogrammed Chip for NM-C921 and soldered it on. (No pins shorted after checking...
                                        02-23-2025, 04:25 AM
                                        Lenovo 3000 Series Schematic
                                        Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                        3000 C100 laptop with Braille keyboard
                                        Lenovo 3000 C
                                        C100, C200 - 15-inch XGA screen
                                        Lenovo 3000 N
                                        N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                        N500 - 15.4 inch screen.
                                        Lenovo 3000 V
                                        V100, V200 - 12.1-inch WXGA models
                                        Lenovo 3000 G
                                        G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                        10-04-2024, 06:05 AM
                                        Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                        09-06-2024, 06:40 AM
                                        This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                        09-06-2024, 06:06 AM
                                      • derradji89
                                        Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                        by derradji89
                                        Hi everyone 🤗
                                        I have a Lenovo MIX 320-10lCR computer.**
                                        1. **Operating System**: Windows 10 ** Education** 64-bit.
                                        2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                        3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                        4. **BIOS Chip Reflashing**: Currently,...
                                        04-19-2025, 03:04 PM
