Got an asus ux305ca for basically parts price. I've already salvaged the m.2 ssd off of it (working fine), so the rest is basically for testing. Just wondering what diagnostic procedures I should go through to narrow down the problem or call the motherboard gone. Now the battery is still good (I assume) it still reads good voltage but I can't test if the laptop is drawing any voltage. When I plugin the battery and press the power button, the power led turns green and I assume that means atleast the motherboard isn't shorted. I also found out the ALC3236 realtek audio driver is the only smc instantaneously getting hot when initially turned on. I don't have any schematics and I tried finding the schematic for that realtek audio smc but I only found a slight variation. I have the necessary tools and I should be able to diagnose even maybe replace some components. I just want to know if this motherboard is even recoverable. I will attach a link to the motherboard. The circled area shows where the location of the water spill from the keyboard side and seeped into the display connector. I only saw a tiny bit of corrosion on the display connector and only about 3 pins looked darker from the far right. The square bit is the audio smc which gets hot when turned on. I haven't tested anything else since, looking for any help or experience with this. Underneath the motherboard is a black cover between the motherboard and the keyboard. The spill looks like it was right on the power side of the board.
edit* now I don't have the right charger for this and I haven't tested it from a charger adapter. I don't know if that'll make some difference. I have only tested from the battery
https://imgur.com/a/GET4O#nXPfNsp
After opening up and looking underneath the motherboard there was a small dried water puddle outline around the power side of the board.
