Apple 820-01326-05 after water spill not start
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    I have this Apple 820-01326-05 that after water spill wont start.
    Chcrger works but charging is in loop. USB-C negotiate to 20V ok, slowly start charging from 0.4A to 0.9A and after that it reset to 0.05A and after 1 sec goes from 0.4A again. loop takes about 6-7 seconds
    I found 12.9V, 20.5V, 3.3V. no short.
    now i dont have schema or BV so i cannot measure more
    laptop was in other shop so i cannot find water spill corosion
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Apple 820-01326-05 after water spill not start
    https://logi.wiki/index.php/Schemati...in_Logic_Board
    820-01326 ❌ ❌ Use 820-01041 boardview and schematic, 820-01326 unavailable, only difference is Vega GPU as far as i know
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      thanks. interresting site.
      DOnt have enybody some starting list of rails for this newer macs?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        I found that U7650 have bad V5REG signal/only one pulse in2sec loop/so i replace IC. now i have stableV5REG, V3REG,G3_HOT, 3.3V ALW, but charger still charge untill draw 1A and then reset to 0.0A and start charging again
        i also dont have
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          found
          SMC_SYSRST_L - 0.0V
          SMC_PCH_SYS_PWROK - 0.0V
          SMC_PCH_PWROK - 0.0V
          SMC_RSMRST_L - 0.0V
          so looks like my SMC is not work
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            this guy have starting sequence diagram for A1990. where can i get one?
            https://www.youtube.com/watch?v=aTV7dAtSb9E
            • piernov
              • Jan 2016
              • 4439
              • France
              https://logi.wiki/index.php/T2_and_C...ence#820-01598
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                veeery nice. i came to half by screen capture his video, but this is way better
                found that this voltage loop works only on charger on battery i have steady voltage
                but still no work even only on battery. i found that CHGR_RST_IN_R is constant 0.0V and not reacting on power button. what is it state when work?
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  nobody knows what this signal suppost to look like?
                  • weritoamador
                    Mr Re-Balling
                    • May 2018
                    i also dont have
                    thanks!
                    • a_p3rson
                      Apple Watch Charging Controller Schematics / Boardview - 820-02601
                      by a_p3rson
                      Hi there,
                      I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                      You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                      This daughterboard uses an interesting...
                      04-21-2025, 11:41 PM
                      20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                      I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                      At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                      Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                      04-09-2023, 08:04 PM
                    • Takeatry
                      Yet another Samsung QLED Boot Loop
                      by Takeatry
                      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                      10-04-2024, 02:57 PM
                      HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                      This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                      09-12-2024, 02:30 PM
                      HP EliteBook 830 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                      This specification for the HP EliteBook 830 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Apple AirPods Pro boardview and 830 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-06-2024, 07:50 PM
