HP DV6-6000 HPMH-41-AB6200 Strange Behaviour
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Model Hp Dv6-6000
    Platform-HPMH-41-AB6200-D00G
    All voltage rails are present,Dc jack Light glows.
    Problem: If i lift U22(Ec Eeprom) and resolder it, m/b starts switching and botts as well but if i switch it off for 10 mins,it refuses to switch again.
    What i have done so far:
    1. I have flashed both the eeproms with working dump from another m/b,still same.
    2. Changed eeprom chips,still same
    3. Changed kbc IT8518,still same.
    I have not noticed any difference in voltages around u22 when it boots and when it doesnt switches.
    What can be the reason friends??
    I seek your advice as i'm really puzzled with this strange case.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP DV6-6000 HPMH-41-AB6200 Strange Behaviour
    Not ati graphics issue as i tried with cooversion from ati to intel-behaviour remains same.
    • sourcebf
      • Jul 2016
      • 433
      • N/A
      What is the component under u22 ( back side of the motherboard )
      Super I/o ??
      • sourcebf
        • Jul 2016
        • 433
        • N/A
        resolder super i/o or any component close u 22
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          SIO is near U22 and not on back side. I have already replaced Sio and it is from working m/b. i have checked connectivity of sio pins and all are fine. No corrosion near sio or U22 or even back side. I have re-soldered all the components near and below U22. All resistance ratings in this area matches with working m/b.
          What next??
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            I have same issue on DV6-600- HPMH-41-AB6300. Its not power on. i checked there was no 5v out from PU4. I just removed and checked PQ115 but it is working. I solder it again. Now the power is coming laptop is working without any problem. if i switch off it again and remove the power adapter. the same problem coming again.
            • piernov
              • Jan 2016
              • 4439
              • France
              What are the voltage on pin 16, 24, 13, 1, 7 and 8 of PU4? Voltage on pin 2 of PQ113?
              You could try to replace PU4.
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                I solved the problem on this board. Problem found on PU4 and PU2. I replaced PU4 and switched on and i found PU2 gets hot. So i replaced it also. Now the problem solved. Thanks for ideas.
                • mahmoodjavan
                  Banned
                  • Mar 2018
                  • 584
                  • iran
                  Model Hp Dv6-6000
                    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 05:30 AM
                  • Natob82
                    Micro Momentary Push Switch?
                    by Natob82
                    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                    12-21-2022, 05:22 AM
                  • grimacelord
                    NEC TurboExpress On/Off Power Switch Replacement Help
                    by grimacelord
                    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                    11-09-2023, 09:49 AM
                  • SluggerB
                    Help making a switch work the opposite way with a relay
                    by SluggerB
                    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                    02-07-2025, 07:57 PM
                  • SidneyCanadas
                    93C46 and 93C56 EEPROM
                    by SidneyCanadas
                    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                    06-14-2023, 01:16 PM
