ibm t40 sometimes boot normal
  • karim011
    • Nov 2016
    • 122
    • Morocco
    Hi guys Pls. ibm t40 sometimes boot normal, sometimes not boot. i changed RAM No results.
  • zomi
    • Nov 2011
    • 510
    Re: ibm t40 sometimes boot normal
    When its not booting normally
    What does it do
    • karim011
      • Nov 2016
      • 122
      • Morocco
      BLACK SCREEN NOT BOOT. When I wait a few minutes. I press on power button it works normal
      • caeb
        • Jul 2017
        • Philippines
        does the power adapter giving the right voltage? you might want to check the power supply area.
        • karim011
          • Nov 2016
          • 122
          • Morocco
          i changed 3 chargers but No results
          • khaahk
            • Dec 2013
            • 810
            • Estonia
            If it has ATI video then need to resolder it, again bga soldering skills are needed.
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • claws77
              FX553VE-DM318T(FX553v) not POSTING
              by claws77
              Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
              Gpu - nvidia geforce 1050ti
              Ssd orion o700
              Hdd hgst721010A9e630
              See images
              What's not working right?
              The system does not even POST, display is black,
              LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
              When did the problem happen?
              My laptop had dual boot setup, ubuntu and windows 10.
              It already had a moklist error, that would occur when i tried to boot ubuntu.
              05-17-2025, 04:09 PM
            • Instafixx
              Macbook A2179 820-01958
              by Instafixx
              Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
              The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
              I checked the Power Sequences below and found this -
              Once a valid external power source (Charger or battery) is connected, the following rails will come online.
              PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
              PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
              05-20-2023, 05:19 AM
            • privato89
              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
              by privato89
              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
              Let's begin:
              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
              03-26-2024, 06:37 AM
            • Luke Anders
              Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
              by Luke Anders
              A few details about the laptop itself:
              Name: Lenovo Legion 5
              Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
              BIOS Version: GKCN60WW
              EC Version: GKEC65WW
              Serial Number: PF39AQ7Z
              Board Model: NM-D562 Rev 3.0
              RAM: 16GB Installed, DDR4 (brand new)
              NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
              I bought this laptop recently from eBay as a faulty device....
              10-12-2024, 05:13 AM
