Dell 3537 la-9982p m/b no power on
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    HI ALL
    DELL 3537 LA-9982P M/B NO POWER ON
    19V IS OK
    (PU100) = +3VALWP & +5VALWP voltage not coming but
    VREG3 & VREG5 voltage coming
    EN2 & EN1 voltage not detect
    PGOOD signal not detect
    how to fix this error
    any one help me pz.....
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Calidebear
    Dell 3537 laptop doesn't boot without embedded display.
    by Calidebear
    I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
    So checked the schematics to bypass this issue.
    Found something but I don't know how to read this schematics.
    Dell 3537 mobo 9982p rev 3
    Schematics attached,...
    03-29-2025, 11:37 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • rddube
    Dell 15-3537 motherboard part identification
    by rddube
    Trying to identify the following part J7 FL M1R in the photo which is on one of the power circuits on a Dell 15-3537 motherboard. Went through the SMD code manual but couldn't find it and google doesn't either.
    Help please and thank you
    02-27-2024, 09:50 PM
