Sony Vaio VPCEH 2S9E PCG-71911 HK1 MBX-247 REV E UMA, shuts down unexpectedly
  • modtool
    • Jul 2015
    • 58
    • Italy
    Hello to everyone, I need help to diagnose an annoying problem with this laptop.
    As the owner said, it has never been dropped and no liquid was ever spilled inside, and I think it's true because there are no aethetic damages to the chassis nor internal oxidations in any part of the board, she told me that it started shutting down randomly.
    I can switch it on by power button, everything works fine, Win 7 loads and works flawlessly, you can browse folders, files, listen to music and browser the internet, temperatures are in normal values (around 50°C for not loaded CPU, around 70°C after 5 minutes of 100% load ) .
    It works both from the battery and from the charger without the battery, the same battery charges both in a shut down state and if you connect the power jack after windows is loaded, though battery voltage is read wrongly both by AIDA and Battery Monitor (3.8 or 4.0 V, but I can measure 12.70 Volt at the battery connector), but after searching on the net, it seems a common problem for this platform, where those softwares can't read properly Voltage values.
    Windows sees battery percentage and charging.
    The real problem is that the system shuts down on different times in two different ways: most of the times it shuts down when browsing the internet, both on video websites and on normal text sites, but it's not unusual to see it shuts down even when no Internet browser is running, or when it is left alone doing nothing but showing desktop.
    It happens both in native Windows 7 and in Win 8.1 .
    It's annoying because it can shuts down within 10 minutes or 1 hours or 26 hours, so you have to wait many hours to test if it holds on...
    And it can shuts down in two ways:
    1- Shuts down immediately screen and power leds, but it still holds +3VPCU
    2- Screen freezes (but you can see squares blinking) like the attached image, then after few minutes it shuts down completely as in option 1, and it still holds +3VPCU.
    First thought was to the battery pack itself, because on Sony support site, there is a warranty statement about VGP-BPS26A batteries retired from the market because they caused overheating of the laptop or the battery itself, but the system shuts down even without the battery...so I changed the charger IC PU10 ISL88731 with a new one, but the system still shutted down randomly.
    These are values of its pins (with red probe to GND) and voltages with battery inserted and charging :
    PU10
    1 NC - 0.00 - 0.00
    2 ACIN 508 - 3.54 - 3.54
    3 VREF 758 - 3.14 - 3.14
    4 ICOMP 765 - 0.00 - 2.20
    5 NC - 0.02 - 0.03
    6 VCOMP 764 - 0.11 - 1.87
    7 NC - 0.00 -
    8 ICM ISENSE 740 - 0.09 - 0.15
    9 SDA 510 - 3.29 - 3.29
    10 SCL 512 - 3.29 - 3.29
    11 VDDSMB +3VPCU 363 - 3.29 - 3.29
    12 GND 000 - 0.00 - 0.00
    13 ACOK 520 - 4.65 - 4.65
    14 NC - 0.02 - 0.02
    15+16 VFB 238 - 0.00 - 12.73
    17 CSON 146 - 0.00 - 12.74
    18 CSOP 146 - 0.00 - 12.74
    19 PGND 000 - 0.00 - 0.00
    20 LGATE 426 - 0.00 - 1.16
    21 VDDP 436 - 4.96 - 4.96
    22 DCIN 636 - 18.84 - 18.28
    23 PHASE 136 - 0.00 - 14.02
    24 UGATE 599 - 0.00 - 16.98
    25 BOOT 580 - 4.72 - 18.60
    26 VCC 436 - 4.96 - 4.95
    27 CSSN 476 - 19.22 - 19.20
    28 CSSP 476 - 19.23 - 19.21
    The second thought was about the HM65 and its ME part of the BIOS...I dumped the content of the BIOS chip U3 from an external programmer and modified it with a clean ME with the same version 7.0.4.1197, but it didn't solved the problem.
    Then I updated the BIOS to the last R0200Z9, and nothing changed.
    Then I modified the updated BIOS with a clean ME of 7.0.10.1203 version, the system went up and running but the same problem remains.
    Third thought was about the wifi card: it is a combo wifi+bluetooth card and since windows can't drive properly the bluetooth part (Devices manager tells "Windows has stopped this device because it has reported problems. (Code 43) ) I took it out, tried to work with another wifi-only card, only by LAN cable or even not browsing the Internet, but still the notebook shuts down after a while.
    I've also detached all external boards (Right USB board, Keyboard , mousepad and power button board), but still random shutting.
    I'm a little suspicious of the screen freezing, so I tested capacitors on the +VCC_CORE and +VCC_GFX, and I found
    C411 +VCC_GFX 314uF ESR 0.04 VLOSS 1.1%
    C268 +VCC_GFX 313uF ESR 0.04 0.9
    C198 +1.05 470uF NA
    C251 +VCC_CORE (330) 254uF ESR 0.08 Vloss 1.3%
    C228 +VCC_CORE (330) 246uF ESR 0.05 Vloss 1.5%
    C221 +VCC_CORE (330) 246uF ESR 0.05 Vloss 1.1%
    C246 +VCC_CORE (330) 238uF ESR 0.06 Vloss 1.4%
    I thought it was a good idea to change 4 caps on +VCC_CORE with new ones of around 340uF, but didn't change +VCC_GFX ones, and still shutting down randomly.
    Next, after searching a lot on the Internet, I found that many problems on these Sony mainboards are linked to UVP protection and Thermal multi circuitry, so I studied them to understand how they work, but please can you explain me better if I misunderstood something?
    Firstly I tested if the PU8 circuitry worked well, heating up some of the thermal resistors to 150°C , one at time, which manages the SHDN# signal (PR217 , PR253, PR210 , PR223, PR233, PR224, PR243, PR198) responsible for many thermal interruptions, and the Thermal circuitry worked well, because every heated thermal resistor made system shut down in a similar way as the faulty one.
    I then unsoldered PU8 but still the same random shutting downs.
    I then unsoldered also U8 (CPU Thermal sensor) and U21 (Audio jack Thermal sensor) but still same problem.
    I then found 4 other thermal resistors, (unsoldered them and they measured the expected values), then I heated them the same way as the other ones, but system didn't shut down this way
    PR226 470k/04 NTC VCORE hotspot 0.11 - 0.84
    PR222 470k/04 NTC GFX Hotspot 0.11 - 0.82
    PR218 10k/06 NTC near GFX inductor 0.44 - 0.44
    PR225 10K/06 NTC VCORE Phase1 L 1.15 - 1.15
    Then I went on studing the "OVP for VEDS" circuitry, and I found another thermal resistor, this one made of a PTC (Positive Thermal Coefficent), PR156.
    I unsoldered it, measured the correct value, and soldered again on board.
    Then I heated PR156 while the system was on, and after a while it trigger the OVP , shutting the system down but this time there was no more +3VPCU since OVP opens PQ32.
    Since all this circuitry is linked to the +3V_RTC voltage, even detaching the power jack and reconnecting it, was not sufficent to normalize the OVP (and to make PQ32 closes again, giving again +19 volt to the entire board) but it is necessary to short the +3V_RTC for a few seconds.
    Correct me if I'm wrong but this way I think that I've found that the OVP circuitry is not the culprit in the random shutting down of this board, because when it shuts down randomly (the main problem) PQ32 is still closed and +3VPCU is still working.
    In fact, after each random shut down, I can power up the system immediately, and it wakes up.
    Instead, when the OVP circuitry is triggered, you can't start the system until you detach +3V_RTC from some seconds.
    PR156 470/06 PTC THRM PROT for PQ32 GND - 0.41
    Sadly I have no oscilloscope to test Y1 and Y2 frequencies.
    I changed CPU, RAM banks and HDD.
    Have run memtest for over 40 hours and system didn't gave any errors and didn't shut down.
    From a general point of view, it seems to me that some IC (maybe PU14 ISL95831, PU9 PM6686, PU13 RT8207, PU12, PU7, U7, or others) pulls down ALL_SYS_PWRGD (that is VR_ON on PU14) when the random shut down is triggered, but how can I find the culprit one?
    Even in frozen screen, I have measured all main tensions (+VCC_CORE, +VCC_GFX, +1.5V_SUS, +1.05V, +3V, +5V, +0.85V) and they seems to be what you can expect.
    General measures:
    PL8 11 Ohm +1.03V
    PQ40 pin3 53 Ohm +0.88V
    PL14 311 Ohm +5.07V
    PL13 355 Ohm 3.32V
    PL12 105 Ohm +1.49V
    PL9 22 Ohm +0.31V
    PL10/PL11 16 Ohm +0.71V
    What I will try next:
    Unsolder Q14 and Q13, linked to SDHN# signal
    Unsolder PR118, responsible of pulling down 3VEN
    Change capacitors C411 and C268 on +VCC_GFX ones
    Do you think that this kind of fault maybe is due to the PCH HM65?
    I can change it to a new one...
    P.S.
    There are 2 errors in the HK1 schematics I have:
    PR243 is not for thermal protection of PU3 but for PU13
    PR156 is not for thermal protection of PQ62 but for PQ32
    You can find the previous therm resistors near the respective ICs.
  • piernov
    • Jan 2016
    • 4436
    • France
    Re: Sony Vaio VPCEH 2S9E PCG-71911 HK1 MBX-247 REV E UMA, shuts down unexpectedly
    Are you sure it's not an operating system issue?
    I have no idea what could cause this, but since it is showing artifacts on the screen I would say it's related to graphics, GPU or VRAM for example.
    • modtool
      • Jul 2015
      • 58
      • Italy
      Hi Piernov,
      thank you for your suggestion!
      I've tried both native hdd with native Win 7 and with another hdd and Win 8.1, but the same random shut downs occur .
      I didn't try to install from scratch an O.S. , but since the shutdown doesn't give any BSOD and doesn't reboot the system (as when a BSOD is triggered) I feel that it's hardware related.
      In Windows Event Manager - Administrative Events . I can see many red and yellow events related to BTHUSB (as I said, the BT part of the wifi card is not working, it shows an error 43 in device manager, but shut downs happen even without the wifi/bt combo card), and Kernel-power related ones 41(63) when a shutdown occurs (The system has rebooted without cleanly shutting down first ).
      Since the system is UMA, it doesn't have discrete GPU but only the one inside the core i5, and uses main RAM memory for graphics tasks .
      Of course I cleaned and inspected both RAM slots and found no problem.
      "Have run memtest for over 40 hours and system didn't gave any errors and didn't shut down."
      It seems somehow o.s. related, it's like the o.s. triggers something while using some function or power state, but I tested with both "AIDA Stability Test" and "Furmark", separetely and together for a max of 6 hours, and it gave no signs of instability, no shut downs, and temperatures were max 73°C for CPU.
      I will take some measures around RAM voltage and VCC_CORE PWM and write them here.
      • modtool
        • Jul 2015
        • 58
        • Italy
        Hello, it's been a looooooong time since I didn't work on this motherboard, just because the owner didn't really need it, but some weeks ago I took it out off the shelf and did some other operations...
        I reballed the HM65, but after many hours the system again shutted down in the same manner...
        I changed the HM65 (and refreshed the ME to a clean one) to a new one, and still the same shut down fashion.
        Then I changed another time RAM banks, but this time I didn't use the same brand/latencies/speed values as I did in the previous tests,, two completely different banks, and guess what...not only the system was able to start and use them in Dual Channel @128bit mode, but it is now rock solid !
        Never had other shut downs nor freezes like before, I kept it working on youtube @FullHD for one continuous week and yesterday I delivered back to the owner.
        Thanks to piernov for the hints, I will try to mark this thread as solved
        • huzo
          HP Omen shuts down when loading OS
          by huzo
          The model is 15ec-1061nm
          Board number is DAG3EDMB8D0​
          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
          10-29-2024, 12:05 AM
        • chaos-theory
          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
          by chaos-theory
          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
          03-14-2025, 05:37 PM
        • baglaivlad
          A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
          by baglaivlad
          Hello everybody!
          Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
          After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
          11-20-2024, 08:14 AM
        • samuelphirik
          Dell inspiron 15 7567 sudden shuts down
          by samuelphirik
          Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
          During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
          I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
          Now I've noticed that laptop...
          07-02-2023, 05:45 AM
        • nickgronk
          Hisense 55H6570F boots, loads then shuts down -
          by nickgronk
          I have a Hisense 55H6570F that gets the the boot loading screen for android and then shuts down. Oddly I hear a crackle on the mainboard as shown in the picture - nothing looks blown. The tv will boot every time, but when it reaches the loading statge of the anroid logo you can hear crackling on the board and it shuts down. What am I looking for (other than buying a new set) ? Inside the square is where I hear the crackling
          08-05-2024, 11:02 AM
