My Lovely Clevo P650rp6-g No Picture and CPUand GPU Stay Cold...
  • German112
    • Jun 2017
    • 30
    Hello dear badcaps forum, I have a big problem .. My Clevo clevo p650rp6-g notebook makes problems.
    explanation
    The notebook goes on (Power Button lights)
    Graphics card fan turns
    Cpu fan does not turn
    Cpu and graphics card remain cold
    Display has a black screen
    About HDMI does not drive high.
    Already tried:
    - RAM memory changed
    - Bios Battery Change
    - all components separate
    Does somebody has any idea? Just because CPU and GPU remain cold ?!
    I already have the Schematic but I do not know where to start
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: My Lovely Clevo P650rp6-g No Picture and CPUand GPU Stay Cold...
    It's not simple, have you a tester ?
    • German112
      • Jun 2017
      • 30
      Yes I have a Tester and i Have the Schematic!
      But i dont know what the First Steps....
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        The file you have posted isn't a schematic file but service manual that don't help us.
        look on motherboard, somewhere there is a code to identify the exact model.
        With this code you can search on internet or on this forum if exist a schematic or boardview file for free. But such repair requires that you weld or change some components. I suggest you to get help from a person with the right skills.
        • German112
          • Jun 2017
          • 30
          Hey, The Schematic ist on the Last Pages... The Notebook is New only 5 Months ... The Motherboard costs 800Euro ... :/ I Hope Badcaps can Help me or a Person From Germany there Repair Moey =P
          • German112
            • Jun 2017
            • 30
            Hello, can someone tell me if the clevo (ami bios) a blind flash is possible? With a button combination !?
            Or is there someone from berlin or germany to help to repair Thema Motherboard for€
            • German112
              • Jun 2017
              • 30
              Need A Schematic for 6-71-P65S0-D02A
              Please
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                Check this schematic with your Motherboard and inform me.
                • German112
                  • Jun 2017
                  • 30
                  Thank you it is right! Does anyone have an idea where I should look for the error? If no image comes and CPU and GPU remain cold?
                  Can it be the bios? or?
                  • raajkumar
                    • Mar 2015
                    • 354
                    • Srilanka
                    You should check at +VCC_Core and +GFX_Core generator chip. It is located nearby to CPU.
                    • German112
                      • Jun 2017
                      • 30
                      Thanks a Lot, Where i Find the VCC? oder +GFX?! Which Part i Must Check? .... I Hope Anyone Can Help me... When it Works i Spend for Badcaps ....
                      • jasko_jacker
                        • Oct 2014
                        • 1137
                        • italy
                        probably a bios issue, but (no power on notebook) find PL14 -> 3.3V and PL19 -> 5v
                        • German112
                          • Jun 2017
                          • 30
                          Hey,
                          PL14 have 3,38V and PL19 Have 5,23V
                          AND U57 have 3,38V on PIN 1,2,3 5,6
                          • German112
                            • Jun 2017
                            • 30
                            PL6 have 0,00V ?! is this right?!
                            • jasko_jacker
                              • Oct 2014
                              • 1137
                              • italy
                              I'm sorry, I indicate PLxx to example for what type of component you must search, find and check PL14 and PL19 . I haven't a hight resolution board image
                              • German112
                                • Jun 2017
                                • 30
                                Ok ... Pl14 anderen pl19 habe ich checken they Works ok 3,38v anderen Themen other 5,38v .
                                Ohne question again... Thema CPU Fan dont Spin only Thema GPU Fan... Ist ist possible that Thema BIOS ist corrupt from one day to the other
                                • jasko_jacker
                                  • Oct 2014
                                  • 1137
                                  • italy
                                  In this model all main component are soldered, so you can't try to replace cpu or gpu. With an oscilloscope is possible to see if bios work correctly but in this case only a reprogramm can help you to exclude a bios U57 issue.
                                  Other tests are possible on U62 KBC IT8587 but require a lot of time.
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3561
                                    • slovakia
                                    what about post card?
                                    • jasko_jacker
                                      • Oct 2014
                                      • 1137
                                      • italy
                                      I don't know what instruments for tests are available
                                      • German112
                                        • Jun 2017
                                        • 30
                                        I have another question! In the photo in red did I measure Volt there? If The Notebook is on ?!
                                        On the CPU I measure 1.2 Volt - 1.0 Volt on the South or Northbridge likewise only not on the GPU !?
                                        Is there someone here the vllt the Mainboard against payment repaired?
                                        • Günter Schuch
                                          searching for Schematics & Boardview for Clevo P641HK1
                                          by Günter Schuch
                                          hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                                          Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                                          05-14-2025, 06:34 AM
                                          Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic
                                          Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic...
                                          10-04-2024, 03:59 AM
                                        • TecnicaNTT
                                          Convert Clevo PC70DD to UMA
                                          by TecnicaNTT
                                          Can somone please help me unlock or convert this Clevo PC70DD2 BIOS to UMA only?
                                          The motherboard just burned a hole in the GPU VRAM VRM circuit and now there is a 19 Volt short spread across the GPU and VRAM side. I isoalted both circuits from the rest and now I can get the laptop to work and display image with integrated Intel graphics but crazy fan spin and shutdown after some minutes because of missing dedicated Nvidia GPU.
                                          Laptop: Clevo
                                          Model: PC70DD2
                                          Serial Number: NPKC70DD2000E0017S
                                          Motherboard P/N: 6-77-PC70DD2-N02C-1D
                                          Motherboard S/N: NKPC70D...
                                          11-12-2024, 05:14 AM
                                        • monitron
                                          Bios Clevo NL51RU
                                          by monitron
                                          I am struggling with a Clevo NL51RU linux laptop that does not boot because of a corrupt main bios.
                                          I did not succeed to build a new bios. Maybe somebody has more experience with this laptop and can build a working bios for me or has a working dump.
                                          Clevo NL51RU
                                          ser: NKNL51RU0001D00318
                                          Many thanks!...
                                          05-27-2024, 11:02 AM
                                        • eukal
                                          Clevo n240lu bios too big
                                          by eukal
                                          Hello i have an Clevo N240lu from a friend that doesn't start anymore. It power on but not display black screen and after few seconds fan spin at full speed.
                                          I have try to replace ram on both slots but nothing so i think the bios is possibly corrupted.
                                          I have backup the bios and download a new one on the clevo website but the size is too big.
                                          Could you help me to have the good size bios ?
                                          Thanks....
                                          01-07-2024, 08:50 AM
