My Lovely Clevo P650rp6-g No Picture and CPUand GPU Stay Cold...
  • German112
    • Jun 2017
    • 30
    Re: My Lovely Clevo P650rp6-g No Picture and CPUand GPU Stay Cold...
    Have measured all the pins: these are the results
    Pin 11 = 0.00V
    PIN 12 = 3.38V
    "PIN 13 = 0.00V
    PIN 14 = 3.38V
    PIN 10 = 3.38V
    PIN 8 = 0.00V
    PIN 9 = 0.00V
    PIN 13 With 200OHM measurement = no strike nothing happens at the display
    • piernov
      • Jan 2016
      • 4437
      • France
      #42
      @jasko_jacker that's what I'm saying. The reason VCCGT_PG is low is because VCCGT is absent. However this disturbs me a bit because it is the first time I see VCCGT required for PM_PCH_PWROK… So I'm not sure what tells the CPU to turn on VCCGT.
      EDIT: probably works the same way as VCore since they use the same component. The regulator first outputs some voltage as soon as it is enabled and then the CPU sets the regulator's output voltage.
      • German112
        • Jun 2017
        • 30
        PL22 has the following results, I have equal PL20 and PL18 measured with these have exactly the same designation and sit side by side
        PL22 = 0.00V
        PL22 OHM = 04.2OHM
        PL20 = 0.00V
        PL20 OHM = 02.3OH
        PL18 OHM = 02.3OH
        PL18 = 0.00V
        ON PU10 i have on PIN:
        2= 2,80V
        3= 1,01V
        4= 0,07V
        5= 1,01V
        7= 5,02V
        12= 0,35V
        I Hope the Best =O
        • piernov
          • Jan 2016
          • 4437
          • France
          #44
          I thought you had VCore? You should be getting 1.2V on PL18 & PL20.
          Also those readings are not what's expected…
          Pin 2 seems a bit low but that should be OK.
          Pin 3 is OK
          Pin 4 should be 1V, being 0V would prevent VCore and VCCGT from coming up.
          Pin 5 is OK
          Pin 7 is OK
          Pin 12 should be 1V, again, 0V would prevent VCore and VCCGT from coming up.
          Double check your readings. But if they are right, I don't know what's going on. The CPU seems to be asserting ALERT# when it shouldn't be.
          EDIT: forget what I said about Pin 12, should be ok since PR503 is apparently no stuff.
          • German112
            • Jun 2017
            • 30
            Okay but the bios can not be it?
            Okay so I assume that the measurements so far no errors result? Can they say something about it? Or have nsie an idea what I should do next?
            • German112
              • Jun 2017
              • 30
              Nobody have an idea?! :/
              • piernov
                • Jan 2016
                • 4437
                • France
                #47
                At this point I would say there is an issue with the CPU. Not much you can do there.
                What's strange is that you had VCore before, now you don't have VCore anymore…
                • German112
                  • Jun 2017
                  • 30
                  !!! UPDATE !!!
                  Hello everyone, I have a small update to tell. ICh today found a webpage from ONE.de where a comparable notebook is offered.
                  There you should see the keys:
                  FN + G + Press Power Button for a Bios Reset (EC) + (GPU)
                  Now starts the notebook of the CPU is also HOT as well as the GPU but there is no PICTURE. Also not over HDMI and it also does not take Caps Lock on ...
                  Is it very likely that now only one bios is defective?
                  I hope someone has an idea
                  Thanks to all =)
                  HEre is the Website
                  https://support.one.de/faq/content/1...downloads.html
                  • Günter Schuch
                    searching for Schematics & Boardview for Clevo P641HK1
                    by Günter Schuch
                    hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                    Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                    05-14-2025, 06:34 AM
                    Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic
                    Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic...
                    10-04-2024, 03:59 AM
                  • Axton
                    Bios for Clevo P670RP6
                    by Axton
                    My laptop has a GTX 1060 installed, but it is not recognized in the BIOS (see attachment). The chip gets warm and the fans spin. I think there is an error in the BIOS.
                    Could there be a switch to activate/deactivate the graphics card?
                    I am also unable to install an Nvidia driver in Windows.
                    Data about my motherboard:
                    S/N: 1TP670RP6310404
                    P/N: 6-77-P670RP6A-N02A-B#10​
                    If anything else is needed, just let me know.​...
                    09-15-2025, 10:28 AM
                  • TecnicaNTT
                    Convert Clevo PC70DD to UMA
                    by TecnicaNTT
                    Can somone please help me unlock or convert this Clevo PC70DD2 BIOS to UMA only?
                    The motherboard just burned a hole in the GPU VRAM VRM circuit and now there is a 19 Volt short spread across the GPU and VRAM side. I isoalted both circuits from the rest and now I can get the laptop to work and display image with integrated Intel graphics but crazy fan spin and shutdown after some minutes because of missing dedicated Nvidia GPU.
                    Laptop: Clevo
                    Model: PC70DD2
                    Serial Number: NPKC70DD2000E0017S
                    Motherboard P/N: 6-77-PC70DD2-N02C-1D
                    Motherboard S/N: NKPC70D...
                    11-12-2024, 05:14 AM
                  • monitron
                    Bios Clevo NL51RU
                    by monitron
                    I am struggling with a Clevo NL51RU linux laptop that does not boot because of a corrupt main bios.
                    I did not succeed to build a new bios. Maybe somebody has more experience with this laptop and can build a working bios for me or has a working dump.
                    Clevo NL51RU
                    ser: NKNL51RU0001D00318
                    Many thanks!...
                    05-27-2024, 11:02 AM
