My Lovely Clevo P650rp6-g No Picture and CPUand GPU Stay Cold...
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: My Lovely Clevo P650rp6-g No Picture and CPUand GPU Stay Cold...
    CPU VCore present but GPU VCore not present means BIOS not POSTing. Either because it is not loading at all (you could see that with an oscilloscope on BIOS ROM data pin), or a component fails to initialize. It could be many things, so it is hard to diagnose. A POST card may help as @ktmmotocross suggested. It could still be BIOS corruption, even if it does not happen that often.
    • German112
      • Jun 2017
      • 30
      Ich bin tomorow a News BIOS chip anderen Check it...
      Have an idea Is not it when the graphics card is really broken? Dad the notebook still work with the intel hd graphic card? Or is a black screen?
      • piernov
        • Jan 2016
        • 4435
        • France
        Ah sorry this model has an eDP mux, so the dedicated GPU is probably turned off in BIOS, and the Intel integrated GPU is used.
        So the relevant voltage to check is VCCGT which goes to the CPU to power its integrated GPU.
        Also SYS_PWROK should come up if the power rails are working.
        On page 96 of the PDF you can see on the bottom how the PWRGD signals are linked together, and check if any is missing.
        • pyry
          • Dec 2015
          • 37
          • Mexico
          Check the PU14 that you have 2.5v output
          The coils PL8, PL6, PL5, PL4, PL15, PL16 etc ... that have voltages at their outputs
          • German112
            • Jun 2017
            • 30
            Hey Pyry, the Coils have :
            PL8 = 0,00V
            PL6 = 0,00V - 0,01V
            PL5= 0,00V
            PL4= 0,00V
            PL15= 0,00V
            PL16= 0,00V
            PL14= 3,39V
            WITH POWER ON
            I Hope this is ok =P
            • pyry
              • Dec 2015
              • 37
              • Mexico
              #26
              Measure on each of those coils with relation to ground and see if you have a short
              • German112
                • Jun 2017
                • 30
                Sorry stupid question, can they tell me how I can measure the exact? And what values? Or short circuit (beep)?
                • German112
                  • Jun 2017
                  • 30
                  On U40 and U42 The GPU Vbios Chip i have no Voltage?! only 0,02V on 1 Pin ?!
                  • pyry
                    • Dec 2015
                    • 37
                    • Mexico
                    #29
                    With your multimeter measures on the scale of ohms the coils
                    PL8 = 0.00V
                    PL6 = 0.00V - 0.01V
                    PL5 = 0.00V
                    PL4 = 0.00V
                    PL15 = 0.00V
                    PL16 = 0.00V
                    And on the coil you have the lowest resistance there is the short
                    • German112
                      • Jun 2017
                      • 30
                      Okay thank you, I test this evening. According to my measurements is there a defect correct? So one of these must be defective? And could be the problem for my broken notebook? If it works again, I will retaliate with you
                      • German112
                        • Jun 2017
                        • 30
                        Hello, I have another question. Can I measure the coils also in the soldered condition?
                        And which setting on my multimeter must I take? Mega OHM Kilo OHM ?!
                        Do I check the components on ground or red on one side and black on the other?
                        What values should I be able to read?
                        • jasko_jacker
                          • Oct 2014
                          • 1137
                          • italy
                          #32
                          In this case to check if a coil is short to ground (0<measure<1.8 ohm)
                          you should set your multimeter on 200 ohm .
                          This type of measurement only on power off without battery.
                          black probe on ground and red on one side of the coil, after if you find a short , depends on the situation you have to desolder one side of the coil to isolate the short. Short occurs when in a circuit the resistence (its measure is the Ohm) between ground and a tension is near to 0, in this case the tension assume value near 0 volt but the amperage is near the max that the
                          generator can provide. But in this situation I don't think there is a short because usually a circuit goes in protection and the power goes off, probably
                          a tension is missing. As Piernov wrote, you shoul check a PWRGD (powergood) a signal that when is present indicates that certain component (like cpu) work properly.
                          • German112
                            • Jun 2017
                            • 30
                            Hello, I now have chamois what Piernov has proposed page 96
                            I have taken a photo and written the data in vllt can someone tell me if there is an error or that is okay
                            Thanks to all those who help me
                            • jasko_jacker
                              • Oct 2014
                              • 1137
                              • italy
                              #34
                              Seems to be an issue on SYS_PWROK_R , read voltage on R270 no ground side that is always 0 volt, and pin 12 on U25D pag 96 or U62A pin 124 ITE IT8587 pag 97.
                              • German112
                                • Jun 2017
                                • 30
                                Hello, so on PIN 12 I have 3.38Volt
                                And Pin 13 has 0.00V
                                And ON PIN 124 i Have 3,38V Look at the Picture PLS
                                Have a photo taken is correct the occupancy as I have measured?
                                Does this mean that this chip is defective? Or is the problem somewhere else?
                                • jasko_jacker
                                  • Oct 2014
                                  • 1137
                                  • italy
                                  #36
                                  U25A_B_C are AND port in series , this means that to obtain an OUT voltage on pin 11
                                  U25D both pin 12 and 13 must be hight (3.3 v). In this case if pin 13 is 0 volt no voltage out from pin 11.
                                  We start from U25C, as you wrote, ALL_SYS_PWRGD U25C pin 10 is hight 3.38 v (repeat measurement on this pin) so to have hight on U25C OUT pin 8 , DELAY_PWRGD must be hight = 3.3 v, measure this pin (pin 9 U25C). If there is a missing voltage the problem reside in other place and not in ITE chip because we have a right out from it.
                                  Power off notebook and measure in ohm (200 ohm on tester) , red probe on pin 13 U25 and black on ground
                                  • jasko_jacker
                                    • Oct 2014
                                    • 1137
                                    • italy
                                    #37
                                    this is the right situation all IN pin on U25 must be 3.3v
                                    • jasko_jacker
                                      • Oct 2014
                                      • 1137
                                      • italy
                                      #38
                                      this is the right situation, all 3.3v on U25 IN pins
                                      Write on this image the value you read on U25 pin 4,5_9,10_12,13
                                      • piernov
                                        • Jan 2016
                                        • 4435
                                        • France
                                        #39
                                        German112's measurements are ok.
                                        R269 is no stuff. VCORE_PG is there on one pad (as we could already predict since VCore is there and OK).
                                        VCCGT_PG is *not* there on the other pad.
                                        I'm not sure why VCCGT would not come up though…
                                        Anyway, check voltage on PL22, and pin 2, 3, 4, 5, 7 and 12 of PU10
                                        Also check resistance between PL22 and ground.
                                        • jasko_jacker
                                          • Oct 2014
                                          • 1137
                                          • italy
                                          #40
                                          But SYS_PWROK_R is 0v it should not be hight ?
                                          and pin VCCGT_PG is 0 volt it should not be hight ? Otherwise how can pin goes hight to send 3.3 volt on PM_PCH_PWROK ?
                                          • Günter Schuch
                                            searching for Schematics & Boardview for Clevo P641HK1
                                            by Günter Schuch
                                            hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                                            Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                                            05-14-2025, 06:34 AM
                                            Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic
                                            Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic...
                                            10-04-2024, 03:59 AM
                                          • TecnicaNTT
                                            Convert Clevo PC70DD to UMA
                                            by TecnicaNTT
                                            Can somone please help me unlock or convert this Clevo PC70DD2 BIOS to UMA only?
                                            The motherboard just burned a hole in the GPU VRAM VRM circuit and now there is a 19 Volt short spread across the GPU and VRAM side. I isoalted both circuits from the rest and now I can get the laptop to work and display image with integrated Intel graphics but crazy fan spin and shutdown after some minutes because of missing dedicated Nvidia GPU.
                                            Laptop: Clevo
                                            Model: PC70DD2
                                            Serial Number: NPKC70DD2000E0017S
                                            Motherboard P/N: 6-77-PC70DD2-N02C-1D
                                            Motherboard S/N: NKPC70D...
                                            11-12-2024, 05:14 AM
                                          • monitron
                                            Bios Clevo NL51RU
                                            by monitron
                                            I am struggling with a Clevo NL51RU linux laptop that does not boot because of a corrupt main bios.
                                            I did not succeed to build a new bios. Maybe somebody has more experience with this laptop and can build a working bios for me or has a working dump.
                                            Clevo NL51RU
                                            ser: NKNL51RU0001D00318
                                            Many thanks!...
                                            05-27-2024, 11:02 AM
                                          • eukal
                                            Clevo n240lu bios too big
                                            by eukal
                                            Hello i have an Clevo N240lu from a friend that doesn't start anymore. It power on but not display black screen and after few seconds fan spin at full speed.
                                            I have try to replace ram on both slots but nothing so i think the bios is possibly corrupted.
                                            I have backup the bios and download a new one on the clevo website but the size is too big.
                                            Could you help me to have the good size bios ?
                                            Thanks....
                                            01-07-2024, 08:50 AM
