The curse of the overheating graphics chips
  • vince88
    • Feb 2008
    • 120
    The curse of the overheated graphic chips (here below called GPU or Graphic Processing Unit) is similar to the badcaps plague: a badly conceived and processed device found its way into poorly designed system !
    For the GPU curse, it is a perfect storm of
    [1] a badly designed GPU e.g. NVIDIA chip with silicon hot spots, combined with the wrong bumping solder balls and defective packaging underfill. If the GPU chip overheats, the balls will crack and disconnect the GPU from the motherboard. Because in most laptop the GPU BIOS interrupt the boot BIOS during boot, the laptop will then not boot even though the laptop lights, CD and fan are working. In some cases, the laptop will nevertheless boot, but the display will be split, full of squares, or some component powered through the GPU e.g. WLAN will not work\
    [2] very poorly thermal design of the laptop, causing GPU overheating and therefore ball cracking. For example, most of the laptop I gathered have a single heat-pipe from the GPU to the chipset to the CPU to the fan, instead of a dedicated heat-pipe for the GPU to the fan distinct from the heat-pipe CPU to fan.
    I just reviewed the stack of failed laptops; I hope that this list will help people that wonder why their laptops are not booting while all the lights/CD/fan are ON. The list is not exhaustive, but represents documented cases of the overheated GPU curse.. All these failed laptops were quite expensive when first bought, and a significant loss for the small business. Some laptop families e.g. Dell XPS 'M' or Dell Latitude D630 have a 100% failure rate after a few years due to overheated Nvidia GPUs.
    When I have time, I will attempt to reflow all these GPUs, even though I know that the fix will only be temporary L
    List of Laptops with GPU induced boot problems:
    HP Pavilion DV6000 model DV6110US
    CPU: AMD Turion X2 64 2x1.61GHz
    GPU: Nvidia 7200 Go
    Boots, WLAN (powered through the Nvidia chip) not working
    HP Pavilion DV5000 model DV5120US
    1.8AMD turion-64
    ATI Radeon Express 200m
    No Boot. All lights ON
    HP Pavilion DV8000 model DV8315nr
    1.8AMD turion-64
    ACER Aspire 5552-3691
    AMD Athlon Dual-core P340 2x2.2GHz
    ATI Mobility Radeon HD 4250
    HP Pavilion DV4 model DV4-1222nr
    AMD Turion X2 64 2x2.1GHz
    ATI Radeon HD3200
    Dell Inspiron 9400 Model PP05XB
    Intel Core 2 Duo 2x2GHz
    NVidia
    Boots, screen full of small squares of characters
    Dell latitude D630 Model PP18L
    Intel Centrino Duo 2x2.2GHz T7500
    Nvidia GPU Quadro MVS 135M
    Boots, two screens split horizontally, then full of small squares of characters. O/S VGA OK.
    Dell XPS M1530
    Intel Core 3 Duo 2x2.4GHz T8300
    NVIDIA GeForce 8600M GT
    Single heatpipe CS>GPU>CPU>Fan
    Dell XPS M1330
    Nvidia GeForce 8400MGS
    Dell XPS M1210
    Intel Core 3 Duo 2x2GHz T2300
    Nvidia GeForce
    No more Boot. Lights ON and blinking
    HP Pavilion DV2000 model DV718US
    Nvidia GeForce GO6150
    No Boot. All lights, CD drive, fan ON
    HP Pavilion DV2500 model DV2416US
    AMD Turion X2 64 2x1.8GHz TL-62
    NVIDIA GeForce 7150M
    HP Compaq Presario CQ50 Model CQ50Z-100
    NVIDIA GeForce 8200M G Graphics
    HP Compaq Presario V6500
    AMD Turion 64 2.3GHz
    Nvidia Nforce 630m
    HP Compaq Presario V6000
    AMD Sempron 2.3GHz
    NVidia GeForce Go 6150
    Toshiba M110
    Intel Core Duo processor T2250 2x1.7GHz
    Intel Graphics Media Accelerator 950
    HP Pavilion DV6807US
    Intel Core2 Duo mobile T5850 2x2.16GHz
    Nvidia GeForce GT 740M
    Toshiba A205-s5812
    Intel Pentium Dual Core T2330 2x1.6GHz
    Intel Media Accelerator X3100
    Toshiba Satellite P105-S9337
    Intel Pentium Dual Core T27200 2x2GHz
    Intel Graphics Media Accelerator X3100
    Dell Inspiron 6400 E1505
    Intel Core Duo T2300 2x1.66GHz
    ATI Mobility Radeon X130
    Dell Precision M70 Model PP15L
    Intel 2.26 GHz Pentium
    NVIDIA Quadro FX Go1400
    No Boot. All lights, CD, fan ON
    Dell Latitude D610 Model PP11L
    Intel Pentium M 760 2.00Ghz
    ATI Mobility Radeon X300
    HP Compaq EVO800C
    Intel Pentium 4-M 2GHz
    ATI Mobility Radeon 7500
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: The curse of the overheating graphics chips
    its not problem with chip balls it chip itself is defective
    nice list...
    Im Back... sort of...
    • sanjurahul
      • Dec 2016
      • INDIA
      need schematic of hp dv2500 pls
      • Second lappy house
        • Jun 2017
        • 9
        • india
        also mostly found in dell inspiron N5010, N5110, N4010, N4110
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Dell N5010 suffers from a design flaw in the mounting of the cooling system. The GPU side of the heatsink is only secured by a single screw that goes thru a thin strip of stainless steel (not sure, but it does look like steel not aluminum) which is riveted into the copper plate that makes contact with the GPU.
          Over time the mounting strip softens and bends, heatsink separates from GPU and thus the GPU dies. I have been getting around this by putting some hard foam on the inside of the bottom case after replacing the GPU, to keep the heatsink tight onto it. None have showed back up so far, in 2+ years.
          A working TV? How boring!
          • privato89
            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
            by privato89
            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
            Let's begin:
            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
            03-26-2024, 06:37 AM
          • joesmoe91
            Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
            by joesmoe91
            My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
            02-22-2024, 07:38 PM
          • hinisa
            Xiaomi router freezes at boot after re-capping
            by hinisa
            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
            07-08-2023, 05:58 AM
          • tarien
            PS5 EDM031 no power, no lights, boot sequence seemse good
            by tarien
            Got in repair PS5 with EDM-031 PCB. Console dont give any light or beep sound. I checked coils no shorts at all, CPU 1V rail measure at about 0.3ohm is it good? All standby voltages are present. Board take at beggining abou 320mA and then goes to 8mA. Checked bios seems good by reading from logic analazyer. Also try uart code but they gives any HIGH errors. Do its possible that is caused by Southbridge or SSD controller?
            02-27-2025, 11:05 AM
          • torchzack
            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
            by torchzack
            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
            08-28-2023, 07:42 AM
