lenovo g50-70 motherboard ACLU1 / ACLU2 NM-A271 Rev 1.0 does not charge the battery
    lenovo g50-70 motherboard ACLU1 / ACLU2 NM-A271 Rev 1.0 does not charge the battery. In windows it shows that plugin charging but did not charge the battery. Battery tested to another laptop running normally. Where to look for the problem. you can help me. Thanks
    Re: lenovo g50-70 motherboard ACLU1 / ACLU2 NM-A271 Rev 1.0 does not charge the batte
    What Is the voltage at pin6 of Bq charging ic(AC DET)?? Voltages at PQ309 & PQ311??
      pin 6 19v
      with out batrry
      pq309 output 1.9
      pq311 output 1.9
      with batrry
      pq309 0.9
      pq311 0.9
        Do you have any schematic for that laptop?
          yes sir
            Originally posted by rafsad ck View Post
            pin 6 19v
            with out batrry
            pq309 output 1.9
            pq311 output 1.9
            with batrry
            pq309 0.9
            pq311 0.9
            Voltage are in correct. Check all mosfets in charging circuit. Else try changing charging IC
              pin 6 19v
              Check value of resistor PR311 maybe have been open circuit.
              ACDET pin voltage between 2.4V and 3.15V, maybe arround 2.6V
