dell N4030 (PU4603 5v & 3.3v reg.) getting hot!
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello everyone,
    i got dell N4030 that have an power issue. I've notice the PU4603 5v & 3.3v regulator is getting hot.
    i check mosfets around and caps no short.
    i have tried to replaced it but it stilll getting hot too. so i guess something else making it hot. but i need ur help guys.
    here i write down volts reading of PU4603 RT8205B
    1. 0v
    2. 0v
    3. 1.9v
    4. 1.9v
    5. 0v
    6. 0v
    7. .4v
    8. 3.4v
    9. 04.6v
    10. .4v
    11. .4v
    12. 0v
    13. 07.9v
    14. 3.2v
    15. 0v
    16. 19v
    17. 04.9v
    18. 0v
    19. 0v
    20. 0v
    21. 0v
    22. 04.5v
    23. 04.5v
    24. 0v
    tnx in advance..
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: dell N4030 (PU4603 5v & 3.3v reg.) getting hot!
    you just remove the wifi card and check it again. i had the same issue on the same model i removed the wifi card and switch it on, it works fine. now i replaced new wifi card on it.
    • rickybucalan
      • May 2013
      • 322
      • philippines
      tnx for reply but it was't the wifi card.
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        Kbc i/o problem remove the kbc and check.WHEN REMOVE KBC CHECK IC HOT OR NOT.
        • rickybucalan
          • May 2013
          • 322
          • philippines
          remove it? it is ok to romove kbc IC and try without it?
          it doesn't cause more problem if i try it
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Instead of Removing Kbc i"ll suggest to check all jumpers near PU4603 for short to ground. If any of the jumpers shows short to GND then remove that Jumper and see which line is short to GND.all these should be done after removing Pu4603. If short still persists very likely KBC failure.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              This way you will be sure Pu4603 is bad or not
              • imranromi
                • Jan 2015
                • 1290
                • Pakistan
                i try many time about this problem the problem is kbc chip when remove chip plug charger nothing problem
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  this is where i was not sure and feared for da,mages in powering up without KBC. Thanks for your confirmation.
                  • imranromi
                    • Jan 2015
                    • 1290
                    • Pakistan
                    look this links easy guide.
                    https://***********/threads/power-se...cac-dong.9349/
                    • alfasys
                      • Apr 2017
                      • 32
                      • South Africa
                      Hi. I also have the same problem, I tried to follow the link you provided, the page is saying VIP members only, how do I access this info?
                      • imranromi
                        • Jan 2015
                        • 1290
                        • Pakistan
                        i send the pics only what u need?
                        • nbanti
                          • 57
                          Hi, RT8205 IC pin 8 and 17 Have 3.3 and 4.9. That means Power IC is in good condition at this time. Check that PCH is hot. If it is you should change the PCH. I have a problem like this before couple of days. I did change the PCH and problem solved.
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                            Dell Inspiron N4030 Laptop Schematic
                            09259-1 Arsenal DJ1 DIS...
                            10-31-2024, 04:09 AM
                            Dell Inspiron N4030 Laptop Boardview
                            Dell Inspiron N4030 Laptop Boardview...
                            10-29-2024, 04:40 AM
                          • Akhlz001
                            by Akhlz001
                            09-20-2025, 07:15 PM
                          • master3112
                            by master3112
                            07-29-2025, 01:55 PM
