Samsung Nexus 10 Reboot Loop
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    I have here this tablet from a senior person, and is not booting anymore.
    I can see the the "Google" logo and it turns off and on all time.
    I'm 98% sure that the tablet was never tampered or disassemble before.
    I don't have experience with google/android gadgets.
    Any tips Guys ?
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: Samsung Nexus 10 Reboot Loop
    have you tried resetting it ?
    • Seagorman
      • Apr 2017
      • 70
      • Ireland
      Factory Reset may be the only option, the menu to do so is usually accessed by holding down volume up and the power button on start up but can differ from device to device, just google 'Factory Reset' for Samsung Nexus 10, moving up/down through the menu and selecting will be done using the same buttons, can be a little fiddly but take your time and you'll be OK, just be aware that Factory Reset WILL delete all user data so check with owner first, as i said might be no other option, best of luck
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        I have now diassembled the rear cover and disconnected the battery.
        Reconnected battery and now i see the animation of the battery charging, but after 30 minutes, no change, still a reboot loop.
        Yes, i've tried "holding down volume up and the power button", no change.
        Must i assume a dead battery ?
        • petehall347
          • Jan 2015
          • 4440
          • United Kingdom
          so did the reset run ?
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            Like i said, i'm a green leaf with this ...
            What is a reset ?
            Maybe you can share.
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              This is what i get with my ignorance :
              PS: power Botums doesn't validate recovery mode
              PS2 : Battery still not charged
              • Seagorman
                • Apr 2017
                • 70
                • Ireland
                Hi Pasette, try the following:
                Important: If your device is running Android 6.0 and up, you'll need a Google username and password already associated with the device. If you don't have the username and password, you won't be able to use the device at all after reset.
                After following all the "Get ready" steps above:
                If your device is on, turn it off.
                Press and hold the Volume down button. While holding Volume down, press and hold the Power button until the phone turns on. You'll see the word "Start" with an arrow around it.
                Press the Volume down button until you highlight "Recovery mode."
                Press the Power button to start recovery mode. You'll see an image of an Android robot with an exclamation mark (you may also see "No command").
                Press and hold the Power button. While holding Power, press the Volume up button once. Then release the Power button.
                If "Wipe data/factory reset" isn't highlighted, press the Volume down button until it is. Then press the Power button to select it.
                Press the Volume down button until you highlight "Yes" (or "Yes - delete all user data"). Then press the Power button to select it.
                After the reset is complete, press the Power button to select "Reboot system now."
                When you're done, restore your data. Learn how to restore your data on a Pixel phone or on a Nexus device.
                Tip: If your device becomes unresponsive, you can restart it by holding down the Power button for several seconds.
                Let us know the outcome, tanx
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  Please, read the post's above, cause nothing of what you wrote works.
                  Now it's worst, cause i can't even turn off the Sh***
                  It's on a real Loop of "ON and OFF" every 5 seconds
                  LOL ...
                  I love apple and android ...
                  Thanks for the tips, but until now they are useless ...
                  • Seagorman
                    • Apr 2017
                    • 70
                    • Ireland
                    Sry to hear nothing is working passete, not looking too promising, anything different happening if you power the unit with its Power Adapter?, not too familiar with the internals of the android based systems, what happens if you disconnect the battery and try booting using just the power adapter ???
                    • Seagorman
                      • Apr 2017
                      • 70
                      • Ireland
                      Passete if theres a External Memory Card Installed try removing it, unlikely to have anything to do with the problem but then again you just never know, failing that the last piece of advise i can offer you is to download the Windows version of 'Droid Explore', install it and connect your Nexus 10 to the Computer, if 'Droid Explore' detects your device you should be able to select the option to 'Reboot in Recovery Mode' from within the software, I reall hope this is of help to you, awaiting the outcome. fingers crossed
                      • passete
                        Living=Sharing
                        • Jun 2015
                        • 487
                        • France
                        I can't enter the hide menu, cause now the machine is booting every 2 seconds.
                        And impossible to charge, cause rebooting loop doesn't let it.
                        Can this be a battery problem ?
                        • Seagorman
                          • Apr 2017
                          • 70
                          • Ireland
                          I dont think its the battery Passete, disconnect battery and try powering up using its charger, any luck ??? might at least eliminate the battery from the equation
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            It will probably not turn on without a battery. Try removing the battery and injecting 3.7V directly on the battery connector. (without attaching the charger)
                            • passete
                              Living=Sharing
                              • Jun 2015
                              • 487
                              • France
                              Can you tell me which of the connectors should i inject the 3.7V ?
                              I have measured the pins of the battery connected, 2 red and 1 blue are reading 4.1V.
                              Thanks Guys
                              • Seagorman
                                • Apr 2017
                                • 70
                                • Ireland
                                The Red wires are the positive Passete, the Blue wires i suspect would be a sense wires for charging but would need someone to confirm that, the battery is rated at 3.7v so if you're getting 4.1v there may obviously be something amiss, as i stated in one of my earlier posts i'm not too familar with the internals of Android Tablets so maybe Piernov or someone else can comment further.
                                • piernov
                                  • Jan 2016
                                  • 4439
                                  • France
                                  Same here, no experience with that kind of stuff (messed with a few Samsung phones/tablets which wouldn't power on, I wasn't able to fix them).
                                  If the charger is plugged in and the battery is charging, I think reading 4.1V is fine. If the charger is disconnected you should be reading around 3.7V (the voltage is written on the battery sticker).
                                  The red ones are tied together and they are the positive side, black ones are ground, and blue are (I think) data lines.
                                  • passete
                                    Living=Sharing
                                    • Jun 2015
                                    • 487
                                    • France
                                    I use Li-Ion 18650 Batterys (the same ones used on laptops) with my Ecigarette, and they are rated for 3.7V, but when fully charged they read 4.2V.
                                    I will try injecting 3.7V on the red connectors.
                                    PS: i was able to get the hide menu, but when i "hit" the recovery mode, the "approid" start with the crazy loop.
                                    • Seagorman
                                      • Apr 2017
                                      • 70
                                      • Ireland
                                      I'm sorry I am unable to offer any more advice passete, I hope someone else with more knowledge of Tablets may be able to offer you a solution, i wish you all the best and hope it works out for you.
                                      • passete
                                        Living=Sharing
                                        • Jun 2015
                                        • 487
                                        • France
                                        Buddy, don't feel sorry.
                                        We are all here to share and learn.
                                        All your imputs are very welcome.
                                        Thanks for your time.
                                        • kevin_allein
                                          Samsung GU58TU7199 reboot loop
                                          by kevin_allein
                                          Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
                                          The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
                                          03-24-2024, 12:19 PM
                                        • brkie
                                          Samsung UE75TU6905 reboot loop
                                          by brkie
                                          I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                                          I read on Samsung's website (reviews)...
                                          09-04-2024, 01:45 AM
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • natiz
                                          Samsung QE50Q60AA - Reboot loop
                                          by natiz
                                          I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                                          Disconnecting the LVDS cable stops the restart loop but no image.
                                          I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                                          Tested the caps on the left buffer board, no beeps.
                                          What else can be checked?...
                                          08-30-2024, 09:26 AM
                                          09-07-2024, 05:50 AM
