Dell N010 Power IC Problem
  • mikeluke80
    Mike
    • Apr 2017
    • 5
    Hey,
    Hoping for some knowledge share on a little problem i have.
    Trying to repair a No Power Dell N5010 down at board level and ive come accross an issue i havent seen before.
    I have +PWR_SRC from the adapter and to all the places it should be but i have no 3.3v, 5v or 15v coming out of the RT8205B power IC.
    The question i have is, does that mean that it is the IC that is caput or can there be any other influences to stop it regulating the voltages down? Its not getting hot or anything and i cant see any obvious shorts.
    Any help would be appreciated
    Mike
  • khaahk
    • Dec 2013
    • 777
    • Estonia
    Re: Dell N010 Power IC Problem
    If RT8205 is getting power on pin 16, then at least VREG3 and VREG5 should be present. If not - either bad ic or overcurrent (should be hot).
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3598
      • slovakia
      there are one or two mosfets right after the +PWR_SRC and fuse. check it
      • HarryPK
        • Mar 2014
        • 210
        • barabai
        you are right...
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          If Charging Ic Isl88731 is bad,then also no 3v/5v. So check it
          • mikeluke80
            Mike
            • Apr 2017
            • 5
            Thanks for the replies,
            Ive attached the Schematic, on this mobo the I/O board which has the power connector on is seperate and i cant find the details for that on the scheme. There is one power mosfet after the DC jack which has 19.7v coming in on pins 1,2,3 & coming out of 5,6,7,8 but the gate voltage on 4 is only 3.1v ?
            Ive just found that on page 46, i have 3.3v ALW coming into the FET Q4601 so it must be there somewhere.
            • mikeluke80
              Mike
              • Apr 2017
              • 5
              Thanks mcplslg123
              Ive had a quick look at the charger circuit, i have 19.7v coming into the Mosfet PU4503 and also a gate voltage of 19.7v but nothing coming out, i presumed thought that was because it wasnt charging the battery?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3598
                • slovakia
                it is P-channel mosfet
                • mikeluke80
                  Mike
                  • Apr 2017
                  • 5
                  khaahk so i can confirm that i have VREG3 & VREG5 out of the R8205. These are 3.3v_ALW_2 & 5v_ALW_2.
                  Just cant figure out why i havent got anything else out of the controller. Does it need a run signal from anywhere?
                  • khaahk
                    • Dec 2013
                    • 777
                    • Estonia
                    Check resistance on PL4601 and PL4602 relative to gnd. SMPS will shut down if overcurrent detected. It should not be low ohms. If possible change the rt8205 to be sure.
                    • masoksian
                      Dell latitude e7470 not turn on .power buton on off and Run Power problem
                      by masoksian
                      I am dealing with the problem of turning on and off my Dell e7470 notebook.
                      The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                      The system does not turn on, there is no post.
                      I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                      The problem continues in the same way.
                      I tried to turn on the Fn key, nothing came to the screen....
                      02-15-2025, 12:08 PM
                    • Cicciotest
                      DELL IPCML-CT rev a00 pOWER ON PROBLEM
                      by Cicciotest
                      I have a problem with this dell mini desktop, no LED lights up and there is no response from the front power button. It literally feels defunct, with no feedback whatsoever.
                      IPCML-CT motherboard rev.A00
                      CPU: Intel Celeron G5900T
                      I tested the power supply (19.5v correctly) but to be careful I also used an alternative power supply to test, nothing. No LEDs, no power on.
                      I tested the power button pins and they correctly measure 3.3V, so when I press the button or put a bridge with a wire, the pulse seems to be there correctly.
                      06-06-2024, 08:48 AM
                    • Mark01
                      Dell Optiplex 7490 AIO - red power led after flash
                      by Mark01
                      Hi guys,
                      This is my first post! 🚀
                      I have no idea what I’m doing, but I’m learning by trial and error.
                      I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                      07-04-2025, 12:54 PM
                    • zlr8r
                      Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                      by zlr8r
                      hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                      Ill try and give as much info as I can.
                      Dell Inspiron 17 (7786) Laptop
                      Service Tag: 5J0NHT2
                      Bios: 1.9.0
                      When I received this , it would only flicker on the KB backlight for a second, then off and on.
                      Then it started getting weirder!
                      Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                      12-12-2023, 09:31 PM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
