Dell Laptop turn off when press capslock
  • eniac22
    • Jun 2012
    • 124
    • Greece
    Dell Inspiron 3542 turn off when i press the caps lock key even in the bios, i have try other keyboard but with no result.
    Do not do it when i run the keyboard test from Dell diagnostic tools.
  • techman1025
    • Jun 2014
    • 497
    Re: Dell Laptop turn off when press capslock
    Hi
    Retest with a external usb K/B and internal K/B unplugged ?
    Let us know what happens
    Techman1025
    • eniac22
      • Jun 2012
      • 124
      • Greece
      Originally posted by techman1025
      Hi
      Techman1025
      Without the internal keyboard and with a usb keyboard is make the same when i press the caps lock the laptop turn off
      • petehall347
        • Jan 2015
        • 4427
        try running a live operating system and see what happens ..
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3599
          • slovakia
          "even in the bios"
          • eniac22
            • Jun 2012
            • 124
            • Greece
            When i run the keyboard test from dell diagnostic cd caps lock work ok
            • petehall347
              • Jan 2015
              • 4427
              is keyboard set to correct one in the operating system ? this is why i suggested trying live system to see if software issue .
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                if it is same thing wint usnb keyboard and internal keboard disconnected then you ruled out keyboard
                check resistors near keboard connector or kbc... might wana try reflashing bios
                Im Back... sort of...
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Something with the caps lock LED circuit perhaps?
                  • petehall347
                    • Jan 2015
                    • 4427
                    see if sticky keys has been inadvertently enabled.
                    • eniac22
                      • Jun 2012
                      • 124
                      • Greece
                      It's not a software problem because he make the problem even when i am in the bios
                      a use external keyboard without the internal keyboard connected
                      • petehall347
                        • Jan 2015
                        • 4427
                        maybe caps lock shorted led as suggested already .
                        • luckydog23
                          • Apr 2017
                          • China
                          I want to buy a laptop about 400 dollars. I don`t play games and it is just for working.
                          After I read the link, I am very puzzling. If you ever used one of the models, can you give me some suggestions? Thank you very much!
                          http://pc4u.org/best-laptop-under-400-dollars/
                          • techman1025
                            • Jun 2014
                            • 497
                            Ok this is what I would do no power to board at all put your meter on diode mode the red probe on ground black probe on the data lines at k/b connector check resistance on each line they should be close in value also press the cap lock key when testing that line see if resistance changes
                            Techman1025
                            • piernov
                              • Jan 2016
                              • 4435
                              • France
                              @techman1025 it's doing the same thing with a USB keyboard so I don't think he'll see anything on those lines. Except the LED one, since the KBC will output a signal to turn on the LED even if the keyboard is disconnected. If it is shorted to ground (before or after the transistor driving the LED) it may cause the computer to shut down.
                              • techman1025
                                • Jun 2014
                                • 497
                                Hi
                                The test was to comfirm to me that KBC/ firmware is the problem.
                                Techman1025
                                • Seagorman
                                  • Apr 2017
                                  • 70
                                  • Ireland
                                  Do you know if the laptop was the victim of any liquid spillage ?, i had a Samsung recently that had a similar issue when pressing the letters K, L, M. the owner had informed me of a small spillage some weeks prior to the issue occurring, inspection of the Keyboard, its connector & Mobo showed little damage other than a minuscule dried liquid spot at the keyboard connector, cleaning with isopropyl alcohol did nothing to resolve the problem however changing the keyboard did, obviously keyboard short, might be worth checking for spillage ???
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • Naineesh1
                                    DELL inspiron 15-3515 GDM54 LA-L245P Won't turn on
                                    by Naineesh1
                                    I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
                                    Schematic diagram : bios chip volt...
                                    07-05-2025, 01:20 AM
                                  • javieromex
                                    Dell G15 5511 LA-K452P won't turn on
                                    by javieromex
                                    Hello, any help will be apprecited!
                                    • Model: Dell G15 5511
                                    • MB: LA-K452P
                                    • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                                    • Customer reported it was turned off and left plugged in during the night and thats it...
                                    • No signs of liquid damage or burned components.
                                    Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                                    I have checked so far:
                                    04-17-2025, 12:44 PM
                                  • Benzohev
                                    Dell Latitude E5520 does not turn off - OS is loading
                                    by Benzohev
                                    The laptop Dell Latitude E5520 oes not turn off - OS is loading.
                                    I reflashed the BIOS; I removed the HDD, Wi-Fi module, DVD drive - I booted from a flash drive, sent the shutdown command - it turns off for a couple of seconds and turns on again! Maybe someone knows what to do?
                                    07-17-2025, 08:18 AM
                                  • Nagyesz
                                    Dell inspiron 13 5000 - Doesn't turn on, overheating
                                    by Nagyesz
                                    I have a Dell laptop with me, a DELL inspiron 13 5379. It doesn't turn on. After some investigation, I found that the charger is delivering 0-3V instead of 19.5V, and this voltage fluctuates constantly. Additionally, two ICs are overheating. I searched for these ICs, and it seems they are likely related to the issue of not having 19V.
                                    Should I inject voltage somewhere, or should I replace the ICs right away?
                                    So, PU4301 is overheating, and the surrounding area is hot, possibly just because of this IC.
                                    07-13-2024, 11:27 AM
