Lenovo X200 battery standby problem
  • Chieftain
    • May 2016
    • 72
    • Greece
    Hello everyone.
    I have a Lenovo x200. After service problem occurred with battery , I can see it on windows taskbar charging but when I pull off the charger , the laptop turned off.. The battery is new and was 5 hours standby before the problem occurred .. Does anyone know where is the problem? Which mosfet is off ? Thank you
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: Lenovo X200 battery standby problem
    claim the service
    • Chieftain
      • May 2016
      • 72
      • Greece
      CPU fan cleaning, compound and silicon pads changing.. nothing special on service.
      • NConstantinou
        LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
        by NConstantinou
        Dear all,
        i have the above laptop which had a problem with battery. i replaced it with a compatible one..
        the laptop DOES NOT POWER ON..
        with it old battery it does power on.
        i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
        when i shutdown the laptop does not power on.
        does anyone have any solution!
        when is not power on the usb c voltage tester shows 5v 1.3A
        when i disconnect battery and power on and then connect battery the tester...
        12-10-2024, 04:52 AM
      • GabrielS24
        Lenovo E540 battery problem
        by GabrielS24
        Hello! I'm here to look for solutions to reset the EEPROM memory of a Lenovo E540 battery of 62Wh and 540mAh. I even bought a new one on the market (aftermarket BTIBM30) because I couldn't find an original one but it doesn't work. The laptop sees the percentage but blocks the battery charging probably because of the Chinese BMS. In the bios I don't have an option for the battery and I didn't find an older version (v1.57). I replaced the Lenovo BMS with Chinese cells but in windows it doesn't read the battery percentage and says it needs to be changed. I have 12v between D and the red wire....
        04-16-2025, 05:23 AM
      • code share
        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
        by code share
        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
        Here's what I've tried so far:
        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
        • Booted successfully on AC power only with the battery disconnected
        • Visual inspection of the battery — no swelling, burn marks, or connector damage
        • Battery
        04-21-2025, 12:50 PM
      • NConstantinou
        LENOVO GYG41/GYG51 NM-D131 REV:1.0 BATTERY PROBLEM
        by NConstantinou
        Dear all
        i have the above laptop which had problem with charging and was repaired. the laptop battery need to be replace also and i did but laptop did not power on with new battery.
        installing old battery back, power comes on.
        i noticed on battery connector instead of 3.3v on pins 3 and 4, i get 2.9-3.3v and is flactuating.
        can someone help!!!
        11-26-2024, 06:08 AM
      • mrkmpn
        Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
        by mrkmpn
        Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
        This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
        03-13-2024, 01:54 PM
