HP 13-4021np
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    HP 13-4021np
    Hello guys ,
    I Have an Hp 13 with MB da0y0dmbaf0 , this sounds strange but the DC In have 19,5V but dont charge ,
    I didnt do anything yet on the motherboard until I'm certain because this is from a customer a bit complicated
    Any idea ?
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: HP 13-4021np
    If you have schematic post it or make a request on this forum, without it I can't help you.
    • Pascal Komlassan
      • Jan 2017
      • 809
      • TOGO
      Re: HP 13-4021np
      Any Help ?
      • mecha1166
        Anyone here fix a tv and customer cracks panel when they get it home?
        by mecha1166
        About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
        03-29-2024, 11:27 AM
      • Hondaman
        File server with PLEX?
        by Hondaman
        Down through the years I have tried to have more convenient storage and backup. Recently, I have used a USB hard drive enclosure plugged into the back of my WRT-AC1200 router. But when I put photos on that drive, my local Win7 machine grinds to a halt. It takes a long time for thumbnail images to show up in Win7 File Manager, because I may have hundreds of photos in any directory I want to view. So I need to put the photos on my local Win7 machine. But I am running out of space.
        Is the router giving the thumbnails from the USB drive enclosure to the Win7 machine...
        05-19-2023, 12:27 AM
        3000W 9000W 24V to 110V Pure Sine Wave Power Inverter UPS Solar Converter is this a good idea
        by sam_sam_sam
        I just seen this item is this a good idea if why and if not why not
        Here is the website link to it
        https://www.ebay.com/itm/40599879518....c101465.m3507
        08-24-2025, 10:55 AM
      • MMH3
        Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
        by MMH3
        i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
        Never ever i experienced problems with that.
        Now i have one 5050sff machine, where this jumper isnt working at all.
        I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
        The history of the machine is that i used it in my office...
        03-23-2025, 09:28 PM
      • AJ847.63e
        HP Spectre x360 - 13-4005tu DA0Y0DMBAF0 . REV: F..boardview & schematic
        by AJ847.63e
        Hey All,
        Just wanted to see if anyone has the above correct schematic and BV for this model. It seems like there are different variations with the exact same board label and revision as I've found BVRs labeled " DA0Y0DMBAF0 Rev F" which is the board label on the board I have here, but it does not match the board. The board I have has a large MLCC on it (where PR96 is) and when I continuity check it to the lines matching the BVR it does not go to where the BVR says it does, and the BVR lists it as PR96 when it is clearly a MLCC. I thought the revisions maybe mixed up in the...
        10-16-2024, 09:23 PM
