HP Spectre x360 - 13-4005tu DA0Y0DMBAF0 . REV: F..boardview & schematic
    Hey All,
    Just wanted to see if anyone has the above correct schematic and BV for this model. It seems like there are different variations with the exact same board label and revision as I've found BVRs labeled " DA0Y0DMBAF0 Rev F" which is the board label on the board I have here, but it does not match the board. The board I have has a large MLCC on it (where PR96 is) and when I continuity check it to the lines matching the BVR it does not go to where the BVR says it does, and the BVR lists it as PR96 when it is clearly a MLCC. I thought the revisions maybe mixed up in the file names, so I downloaded another one which is labeled the same except "rev E" instead of "F".but it seems like the exact same file.
    The aforementioned MLCC seems to be physically damaged and is reading 2 ohms on both sides but I'm having difficulty figuring out what it's a part of and where it goes since the BVR seems incorrect and I haven't found a schematic.
    Thanks for the assistance.
    For those interested, it was the suspected cap and indeed the BV and schematic are for a different model. Or incorrect. Removed the cap and short was removed, did some continuity checks and it seems like this is just a smoothing cap sitting on +AC_CHG_In. Any idea what value it would be as it would be nice to replace it?
