Mac A1278 J30 820-3115B
  • Billrj
    I'm trying to repair this beer damaged board and I've got 17.x volts up to the U6990. On the U6990, I only have power on PIN 7. Is the U6990 the first thing I should replace?
  • MisterAIL
    PS5 digital / No Power / No Beep / Good power supply
    by MisterAIL
    Brought a non functionnal PS5. Apparently only a bad PSU...
    No beep, nothing.
    After some tests i found this :
    - PSU is fine (12 volts stable)
    - 12 volts line is shorted
    - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
    - By the way, nothing change. No signal, no power, no beep.
    Mesuring all rails with my workbench psu (12 volts input)
    - 0.00 amp drawing
    - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
    03-12-2024, 03:24 PM
  • Mcfeetroy
    Fishing bite alarm drains battery
    by Mcfeetroy
    Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
    08-01-2025, 03:52 AM
  • BTubbs200
    Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
    by BTubbs200
    Dell Latitude 5420 P137G
    Board: LA-K491P REV A01
    I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
    Board seems to have no shorts, all power rails are fine and show high resistance.
    When charger is plugged in, voltage is present in 3.3V rail but absent in others....
    01-24-2025, 08:15 PM
    MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
    I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
    I open it up to find non brands name capacitors in it
    I am not sure how this switching power supply is set up
    Could someone please explain how this power supply works
    Here is the capacitor ESR results
    (1) 47uf@50 volts 0.46
    (2) 47uf@50 volts 0.45
    New 47uf@50 volts 0.35
    (1) 100uf@25 volts 0.34
    (2) 100uf@25 volts 0.35
    New 120uf@50 volts 0.08
    (1) 220@25 volts 0.13...
    10-21-2018, 10:02 AM
  • pcbmaniac
    MacBook A1278 (3115) No PPBUS_G3H Issue
    by pcbmaniac
    Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
    I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
    1. U7000 Measurements:
      • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
    2. Resistors:
      • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
    Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
    • If I also decide to replace the SMC, do I need to order it pre-programmed,
    12-02-2024, 04:12 PM
