Samsung Np300e7a only powers with battery
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hi there,
    i got here this samsung that only turns ON with the battery.
    It doesn't charge and also it doesn't turn ON with the psu
    Motherboard : SCALA3-17 REV 1.3 BA41-07150A HST
    Can't find any schematics
    Please help guys
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: Samsung Np300e7a only powers with battery
    did you check the charger/psu it could have died
    I'm not a expert, I'm just doing my best.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      I use a lab Psu, the same that i used to charge the battery on another Samsung.
      Voltages are low, on 3.3V i have 2.6V
      can anyone post schematics or boardview ?
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        Wierd, i was able to boot with the charger and without battery.
        Rebooted fine, started to clean and defrag and it shut off.
        I still can turn it on, but i have a black screen ...
        What a hell
        • subroto
          • Oct 2015
          • 230
          • Bangladesh
          check gfx voltage first. Most probably the board has internal damage.
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            Reflowed pch and swapped ram, pc is working ...
            This is very wierd
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              Well, this is a real case, if i try to re install windows, it's impssible, i got a reboot loop.
              I guess that i have a problem on the psu line.
              Please, anyone with with the schematics ?
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                will it run a live linux distro ?
                • 2n3055
                  Old Member
                  • Nov 2007
                  • 8
                  Schematics
                  charger power management
                  Page 46 from Petronas 14
                  BA41-01666a
                  Operative Activity Replace Intelligence Wind calm
                  This post has been edited 275 times by 2n3055: Today, 12:93 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • mkdj
                    ASUS X571 no power : battery issue?
                    by mkdj
                    Mark and model: ASUS X571
                    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                    Tests already made:
                    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                    - I have removed...
                    07-14-2025, 09:16 AM
                    09-07-2024, 05:50 AM
                  • techfreak9356
                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                    by techfreak9356
                    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                    09-14-2023, 11:10 PM
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
