Lenovo G500 - No power or charging
  • panandreas
    • Jan 2017
    • 6
    • Greece
    Hi everybody,
    I have a Lenovo G500 with LA-9631P mobo that doesn't turn on. If I connect the laptop to AC power I get no lights or anything that shows that its on a power outlet. Same thing happens if I press the power button.
    I have found some information and schematics on the internet about the laptop and I started measuring Voltages with a multimeter. I have power (20.31V) getting in the mobo but no 3.3V or 5V.
    From the info I have found this laptops has problem with the FETs on the charging circuit. So I measured the voltages on the first FET after the VIN which is PQ301 (A04407AL) and the measurements are:
    • Drain(5,6,7,8): 20.31V
    • Source(1,2,3): 19.78V
    • Gate(4): 19.77V
    Is this normal? Shouldn't the gate has a lower voltage? Shouldn't the voltages between drain and source be almost the same?
    Do you think this is the problem of my laptop or do you have a suggestion for anything else that could be the problem?
    I am attaching some schematics images
    Thanks for your time
  • r0ma1992
    • Sep 2015
    • UA
    Re: Lenovo G500 - No power or charging
    I think PQ301 or PQ302 is damaged. Check resistance between Source and Gate. There is should not be a short circuit
    • panandreas
      • Jan 2017
      • 6
      • Greece
      Unfortunately there is no short circuit between source and gate and that's why I have opened this thread. I am measuring about 200 Kohm which is the resistance of PR304
      • lakrouf
        • May 2015
        • 12
        • 84316327138
        PQ301 P CH is damaged change it.
        • panandreas
          • Jan 2017
          • 6
          • Greece
          I will try to replace PQ301 and report back. Thank you very much
          • peste
            • Dec 2016
            • 13653
            • ROMANIA
            if you have to point B + 19v is ok ... if you did not, change pq 301, pq302, pu301, check pr301, power button.
            • Dr.d
              Help please..Lenovo ideapad 5 14itl05 power and charging problem
              by Dr.d
              I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
              Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
              04-05-2024, 11:48 AM
            • Scoff
              HP Probook 470 G4 - Power and Charging Problem
              by Scoff
              Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
              Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
              07-03-2023, 09:28 AM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
