Hi everybody,
I have a Lenovo G500 with LA-9631P mobo that doesn't turn on. If I connect the laptop to AC power I get no lights or anything that shows that its on a power outlet. Same thing happens if I press the power button.
I have found some information and schematics on the internet about the laptop and I started measuring Voltages with a multimeter. I have power (20.31V) getting in the mobo but no 3.3V or 5V.
From the info I have found this laptops has problem with the FETs on the charging circuit. So I measured the voltages on the first FET after the VIN which is PQ301 (A04407AL) and the measurements are:
Is this normal? Shouldn't the gate has a lower voltage? Shouldn't the voltages between drain and source be almost the same?
Do you think this is the problem of my laptop or do you have a suggestion for anything else that could be the problem?
I am attaching some schematics images
Thanks for your time
- Drain(5,6,7,8): 20.31V
 - Source(1,2,3): 19.78V
 - Gate(4): 19.77V
