How to find shorted rail
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    I got this motherboard few days back when plug in to dc it goes up to 0.7amp and stuck .
    later i found that PL30, PL32,PL34,PL35,PL37 coils are shorted to ground.
    I,m sure all these coils are not shorted to ground due to cpu on board.
    its a bga chip.one of above shorted to ground.
    if i can remove the cpu its easy to find and here iam stuck due to cpu on board .
    please give me a solution to find the genuine shorted rail.
    schematic is attached ..Thank you very much
    sigpic
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Re: How to find shorted rail
    Find out the culprit with Vin of core voltage generator ic or graphics voltage generator ic. Actually most of the short is occurred by ceramic capacitor with Vin of stepdown regulator IC.
    • samanthban
      • Feb 2014
      • 253
      • Sri lanka
      Thanks for your idea
      sigpic
      • samanthban
        • Feb 2014
        • 253
        • Sri lanka
        any other suggestions please welcome!!
        sigpic
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          when I inject 0.9v to PL34 cpu warming up
          sigpic
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Did you solved this problem ? I got a laptop with same problem yesterday. I looked with a magnifier for broken ceramic capacitor, Finally i found a cap on PL32 line +VCCSA area. I replaced it and the laptop working now.
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • survivalbloke
              Surface board, main rail shorted, can't find where
              by survivalbloke
              This is MS board M1029273-001. I'm getting <.2 ohms on output of the second mosfet. Looking at a schematic, I injected 1v/5a to the resistor pin where this mosfet connects to, and it is drawing 3.7a but the only thing getting hot in the thermal camera is this resistor which surprises me.
              Where should I be looking from here?...
              09-06-2023, 03:42 PM
            • im_trying
              MSI GF65 Thin doesn't turn on, shorted on dc-in, how to find the culprit?
              by im_trying
              Hi, thanks for helping.
              The motherboard is from a gaming laptop, msi gf65 thin 10ue, 16W21/11S.
              For starters, it doesn't power on. I measured a "short" on the second DC-IN mosfet, right around the charging port but I don't know how to find the component that's shorting it.
              I already tried checking the mosfet for internal shortage (by desoldering and measuring) but no short. The drain on the motherboard is the one that's shorted, next to the gate (that's not shorted).
              The photo below shows this better than words.
              Thanks for anyone...
              05-12-2025, 04:16 AM
            • someonenotyou
              Dell Vostro 3501 - no signs of life after BIOS read
              by someonenotyou
              Hi.
              I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
              Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
              After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
              Then I took the motherboard out...
              01-27-2025, 05:15 AM
