Need some help with HP 250 G3 dead Motherboard
  • eng.jaudat
    • Aug 2016
    • 63
    • Palestine
    Hello my friends,
    i attached the schematic, my problem that there is no any Voltage on the gates on the power mosfet shown in the figure:
    Which IC should create that missing voltage?
    and whats the expectations of the problem?
    thank u so much.
  • khaahk
    • Dec 2013
    • 765
    • Estonia
    Re: Need some help with HP 250 G3 dead Motherboard
    BQ24738 should create the 25V to open the PQ101 & PQ103. In case of overcurrent it might turn off the fets to protect circuit. Measure resistance at B+, check the fets and then replace BQ24738. Does the board work from battery?
    • tibd
      • Oct 2014
      • 189
      • Sweden
      Have you tried with a known good power supply?
      What is the voltage at pin 12?
      • eng.jaudat
        • Aug 2016
        • 63
        • Palestine
        My friend,
        sorry, which resistance u mean? is it PR103? m trying to replace BQ24738, but its the same problem, i'm not sure if the board work from battery, i don't have charged battery, i will try it within a few hours.
        • eng.jaudat
          • Aug 2016
          • 63
          • Palestine
          Yes my friend, my power supply is very good.
          i have just 0.4 VDC at pin 12.
          • khaahk
            • Dec 2013
            • 765
            • Estonia
            Resistance from B+ relative to gnd to see if there is a short at B+ rail. Have you checked the FETs PQ101 and PQ103?
            • eng.jaudat
              • Aug 2016
              • 63
              • Palestine
              there is a short between B+ and Gnd, FETs PQ101 and PQ103 chedked, and they are good.
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                do you have dc bench PS?
                • eng.jaudat
                  • Aug 2016
                  • 63
                  • Palestine
                  honestly i don't. but i used a genuine HP charger.
                  • ridamouh159
                    • Nov 2014
                    • 365
                    • maroc
                    have you changed PQ103 ؟
                    • eng.jaudat
                      • Aug 2016
                      • 63
                      • Palestine
                      Yes my friend i changed it. same problem
                      • aedler
                        • Aug 2015
                        • tunisia
                        Hi, i have same problem , the board work from battery if i remove the lcd connector ,PQ101 & PQ103 are not shorted b+ not shorted too.can you help me please?
                        • Mazorca
                          • Jan 2017
                          • 463
                          Those are N-mosfets, and they open (work) when the voltage Vgs is lower than Vin, around 10v or so. Check that. Did you physically remove said mosfets? Only good way to test them.
                          • Mazorca
                            • Jan 2017
                            • 463
                            OOPS, Wrong advice. For N-mosfets, Vgs should be higher, usually 32v.
                            • muanpuia
                              • Jun 2014
                              • 19
                              • India
                              Force with a high amperage power supply to see if something becomes hot. It might be caps
                              • tk3000
                                Dead Laptop Motherboard, then refurbished one installed...
                                by tk3000
                                My venerable and old laptop (Toshiba Satellite P75-A7200 equipped with an i7-4700MQ, circa 2014) and previously a powerful machine during its heyday is no more. Have been using it for many years, but about 3 months ago it went kaputt for no apparent reason (left it on overnight [normally it goes to standby mode after some idle time], and in the morning it was cold dead with no boot, no post, no leds; nothing at all).
                                Since the 1990s I have been building custom desktop computers, etc; but it has been few years since my last built one and for the last 15 years I have built very few...
                                08-20-2022, 08:45 AM
                              • DrvLikHell
                                Dell Latitude E6540 - 2nd dead motherboard
                                by DrvLikHell
                                Greetings and sanitations! Several years ago I received some really awesome help on this forum for fixing my monitor (which is still working) so I figure maybe someone can help with this laptop issue.
                                I have a Dell E6540, motherboard 9411P, DP/N:VWNW8. A year ago it died a strange death where at first it wouldn't turn on all the time, but would turn on when it felt like it, then it got worse where it wouldn't turn on at all and I would just get a flashing light. So I replaced the motherboard with a matching part number board. (I still have the old motherboard) Now a year later this...
                                01-30-2021, 02:36 PM
                              • Archimedes
                                HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                by Archimedes
                                Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                Fans are spinning. Blindly could install windows11 and got the device manager...
                                07-30-2024, 05:14 PM
                                ASUS P5GC-MX motherboard recap
                                by momaka
                                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                So here is what the motherboard looked like with its original caps:
                                CPU VRM area up close…...
                                01-27-2021, 11:59 PM
                              • dragon3x
                                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                by dragon3x
                                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                power on.
                                Here are some examples :
                                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                switching supply area).
                                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                than 6.3 V.)
                                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                I replaced capacitors with aluminum-polymer.
                                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                03-21-2025, 02:46 PM
