k451 (S451LN) not turn on(die after a sec,stuck in G3)
  • r ez a
    • Sep 2014
    • 39
    • iran
    hi guys
    i have a laptop here that it just working for less than a sec
    voltages and signales are true for a sec and after that all voltages die
    just 3&5V
    no sus voltage
    no RSMRST#
    nothing changed by program bios n ec
    is any error happend that it stucked in G3 mode?
    tnx for ur help
  • r ez a
    • Sep 2014
    • 39
    • iran
    Re: k451 (S451LN) not turn on(die after a sec,stuck in G3)
    its diffrent with battery
    when it powered by battery,it respond to power key and turn on 1.05VSUS rail
    totally different with ac mode
    anyone has any idea whats wrong with it?
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • RdeveLabs
      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
      by RdeveLabs
      To all the members here...
      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
      05-05-2025, 04:59 AM
    • robante15
      Acer Aspire 4520 won't turn on after reboot
      by robante15
      Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
      It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
      The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
      If I remove the...
      04-06-2024, 06:50 PM
    • masoksian
      Dell latitude e7470 not turn on .power buton on off and Run Power problem
      by masoksian
      I am dealing with the problem of turning on and off my Dell e7470 notebook.
      The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
      The system does not turn on, there is no post.
      I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
      The problem continues in the same way.
      I tried to turn on the Fn key, nothing came to the screen....
      02-15-2025, 12:08 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
