Alienware 17 (R5)LA-9331P short
  • capelord
    • Nov 2016
    • 9
    • aust
    Hi guys ,
    I have a little know how when it comes to this sort of thing , not a lot though. So here is the situation that I find my self in . Not sure how but my laptop died, when ever I plug the power in to the DC jack the blue light on the power lead turns off and you can smell a short coming from the jack. I have google around and so far all it indicates is that there is some sort of short on the board, I can not afford to buy a new board so my only option is to try and find the short and repair it. So far the things that I have found and done are :
    0. I have tested with two different power leads and have checked the out put from them both, both are good.
    1. I have removed the DC jack and plug that in to the power lead , blue light stays on.
    2. I have used a different DC jack , blue light on power lead still turns off.
    3. by passed the DC connector on the board and blue light on lead still turns off.
    4. unabale to try the battery as that is flat, And I don't know of anyone that can charge it for me.
    5. the only thing on the board that looked suss was cap PC102 it has lost the colour off the top and it feels like a small indent on the top. Its the only cap that looks in poor condition.
    5. once the power lead blue light turns of it only gives 0.450 and that drops over time,
    6. using the 0.450 from the power lead and the Schematic I was able to trace the 0.450 to PQ703 and that seems to not be getting the 0.450.
    7. I have checked a few parts to see if the 0.450 is getting through and I have been able to pick it up in the following locations
    PQ501
    PQ502
    PQ503
    PQ504
    PQ512
    PQ507
    PQ508
    PQ502
    PQ511
    PL3
    PL1
    PQ704
    PQ702
    PC905
    PC906
    PQ701
    PC915
    PL702
    PL701
    So far this is all I have checked , any help that you could offer would be good , and any tips on what else I can try , I don't want to waste this laptop.
    I have included photos and the Schematic for it.
    Schematic moved to a new thread --> https://www.badcaps.net/forum/troubl...331p-schematic
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: Alienware 17 (R5)LA-9331P short
    First you start from PL1 or PR703 check with multimeter on ohm range with Ground if showing 0 ohm then something short on main voltage line..so the simple way to trace out short component inject external supply 10 0r 12v with high ampere on PL1. The positive wire on PL1 and negative on Ground and observe the board components the short component will be heat up.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      use pjp point to see where short is......of course using a logic with brain....
      a lab psu will do the rest if u dont want to remove each component or jumper.
      u have short on mail 19 volt rail that power almost everithing in the notebook. i had a similar problem o ndifferent notebook and without a lab psu took me a while to figure out wich component it was, but with a lab psu, u can find the short in lower time.
      it can be a bad 0805 capacitor, or a bad mosfet, or a bad ic .
      • capelord
        • Nov 2016
        • 9
        • aust
        So I hooked up a external supply and only injected 5v I wanted to start small and right away I got smoke and it bubbled up on me (PR703).
        the rest were very hot but didn't bubble.
        I know I will need to replace PQ703 , will I need to replace the other that got hot?
        On a side note I did have a 0850 capacitor blow out as well , I have replaced that one , not the best work I have done but it should do.
        • smali
          • Sep 2014
          • 287
          • Pakistan
          if you inject supply on PL1 side and PR703 heatup its mean your short circuit is after the PR703 as tick in image apply your 5V external after PR703 and observe the board components....and also the PR703 on multimeter after bubbled up the value must show very low ohm.
          Note...i dont understand your 0850 capacitor..what is board part number?
          • capelord
            • Nov 2016
            • 9
            • aust
            Sorry not PR703 it was PQ703 that heated up and bubbled on me, I have marked it with a red arrow, the 3 next to it with the black arrow seem to be leaking and super hot.
            as for where to inject the 5v next you say after PR703 I'm not to sure which side of it I have to do it .
            If you could point out on a picture of the board I will inject there. I have marked it A or B. sorry I'm still new to all this.
            not sure on the board part number ? but its the I marked in the photo saying blown
            • smali
              • Sep 2014
              • 287
              • Pakistan
              As per picture point-B of PR703.
              as per schematic PQ703 and PQ706 are parallel for same purpose.
              you can remove PQ703 temporary just for checking ....but i dont think that your main rail line voltage short with ground is the problem of PQ703...
              • PitViper
                • Nov 2017
                New to the forums, cool to see communities like this.
                After doing a search this is the closest thread I could find to my problem. Keep in mind I don't know about this kind of stuff.
                My issue is with and Alienware 18 with an LA-9332P (rev 1.0) (A00) mother board. The IC labled PQ703 had a total melt down. There are a cluster of 4 ICs (PQ706 PQ703 PQ702 PQ705) that all appear to be stamped as follows.
                6405
                BA3X15
                I'm looking to find replacement ICs, but I have no idea how to find the part.
                I've only done some mild soldering but I would like to try replacing the chip(s) before spending $300 on a new motherboard.
                If nothing else get the chip and give someone else do the soldering.
                This wasn't a cheap laptop so I'm not ready to give up on it when it does what I need it to do.
                • ivmilicevic
                  • Aug 2017
                  • 14
                  • Bosnia and Herzegovina
                  I'm far from expert on this, but according to schematics those chips are P-Channel Mosfets - Si7149DP. They seem to be common in laptops, so they shouldn't be too hard to find.
                  Although it's possible that something is shorted after these mosfets, so even if you replace them with new ones problem could still be there
                  • PitViper
                    • Nov 2017
                    Thanks! Any info is very much appreciated.
                    I was thinking the same thing about there being a short elsewhere. Hoping the chip was just bad. This isnt the first time ive had a problem and both times the same program was running. For some reason I think the program was pushing the GPUs too hard. last time it killed one of the GPUs, now this happened after getting a replacement. But when I only had one GPU everything was fine.
                    • maki
                      • May 2011
                      • 6
                      Hello
                      I have a weird issue with my laptop - Alienware 17 (R5).
                      For a while I worked only on AC (no battery installed) without any issues.
                      Recently I’ve bought a battery. At the beginning it looked like its working fine and after a while I’ve noticed that it isn’t charging.
                      I’ve removed the battery and the laptop wouldn’t turn on AC only.
                      So, now it works fine only on the battery and won’t turn on with AC.
                      Any ideas?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        check dc in fets
                        • maki
                          • May 2011
                          • 6
                          Thanks for the response, mcplslg123. To which FETs are you referring?
                          When AC is connected (without battery) the MoBo has 5V and 3.3V.
                          • boss juben
                            • Oct 2016
                            • 37
                            • philippines
                            Originally posted by maki
                            Hello
                            Any ideas?
                            same problem did any one have solution for this problem but i will try may best to solve this
                            • DynaxSC
                              Extreme High Current & Low Voltage Short Killer ??
                              by DynaxSC
                              Hi Folks
                              I'm looking for a extreme high current short killer solution for a reasonable cost.
                              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                              After taking off the socket, the shorts dissappear again.
                              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                              10-15-2024, 10:13 AM
                            • Stephen
                              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                              by Stephen
                              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                              02-06-2025, 12:03 PM
                            • adelfr2009
                              HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                              by adelfr2009
                              I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                              After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                              09-28-2025, 10:21 PM
                            • Victor Moreira Silva
                              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                              by Victor Moreira Silva
                              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                              Well, my decice specs are the following:
                              Model: Acer Nitro 5 AN517-54-55T5
                              CPU: Intel Core i5-11400H
                              GPU: NVIDIA GeForce GTX 1650
                              Motherboard: GH51G LA-L181P Rev:1c
                              The symptom:
                              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                              05-26-2025, 10:49 AM
                            • aaronkatrini
                              Help me find the short circuit on this WORKING Nvidia GTX1650
                              by aaronkatrini
                              Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                              Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                              04-18-2024, 03:15 PM
