ASUS N56VM power
  • rihiii
    • Nov 2016
    • 5
    • Latvia
    ASUS N56VM power
    Hey guys!
    I have a ASUS N56VM laptop that has no power from power supply...
    And i think i found the problem: https://dl.dropboxusercontent.com/u/...1116174415.jpg
    Now, there is another one of these transistors and i guess it is the same as the blown one: https://dl.dropboxusercontent.com/u/...1116174543.jpg
    Also looking at various sites i know that it is a transistor, but what i cant find out is, what kind of transistor, the package numbers give mo nothing, so i cant find a replacement for this one... also maybe you knwo where could i find the schematic of this laptop? if i would have that i could find the nominals of burned passives in that area also...
    already desoldered both of them the best i could... https://dl.dropboxusercontent.com/u/...1117121428.jpg
    Can anyone help me please?
    Thank you very much!
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: ASUS N56VM power
    UNIKC P0903BEAREV1 Mark=A5
    or equivalent
    ubiq QM3024N3
    • rihiii
      • Nov 2016
      • 5
      • Latvia
      Thank you!
      Didn't find any of those where to buy, but found one similar to specs: NTMFS4C10NT1G
      30V 46A
      would this one be good enough?
      Or maybe this one: SIRA02DP-T1-GE3 ?
      Higher continuous current so maybe will work better and longer?
      • conghuyms
        Request for Help – ASUS G531GW Rev 1.6 – No Power On
        by conghuyms
        I need your support with an ASUS G531GW Rev 1.6 laptop.
        When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
        Here’s what I’ve checked so far:
        • Motherboard has been removed for inspection.
        • 3V and 5V always-on rails are present (3V/5V_ALW).
        • 1.8V and 1.09V at the PCH are present.
        • I don’t have the boardview/schematic, so troubleshooting is limited.
        • I tried checking the power button signal from the
        07-20-2025, 09:14 PM
      • Duranitron
        Asus x512dk rev 2.1 power on problem
        by Duranitron
        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
        11-26-2024, 10:22 PM
      • Thomas Smith
        Asus Tuf gaming fx506l no power, mosfet does not open
        by Thomas Smith
        Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
        Initial Symptoms:
        • The laptop has no power at all (no LEDs, no fan spin).
        • No 3.3V or 5V present on the board.
        • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
        Power Rail Checks:
        1. Charger input (FETs PKCH2BB)
          • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
        2. BQ24780S Charger IC:
          • VCC and ACDET are present.
          • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
          • Shunt resistor has 10Ω to ground.
        03-30-2025, 03:38 AM
      • TimeRabbit07
        Asus FX517ZC charges but power button does nothing
        by TimeRabbit07
        Hi all!
        I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
        Here are its various numbers and identifiers:
        Model short: FX517Z
        Model long: FX517ZC-HN114W
        SN: NANRCX01S57842E
        CN: 3SDB 12M
        MFD: 2022-10
        Motherboard model: DA0NJLMBAE0 REV E
        Symptoms:
        The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
        History so far:
        The...
        09-04-2024, 05:48 PM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
