HP Quanta U99 Board - 15F Series Laptop - Dead
  • katfish
    • Jul 2016
    • 76
    Looking for a little input.
    Customer brought in this laptop, mentioned in the title, doa. Found the power input jack damaged and sent 19V down the AD_ID line. Get's no light when plugged in with a good jack. Found R336 100OHM was toast. Replaced it and C605. R329 and R328 are good. And +3VPCU is present. Still no light.
    I have a feeling IT8528E EXA is now toast. But I don't have one handy to swap out. Is EXS a suitable replacement?? Saw one on eBay.
    Is there anything else I should look for ... since 19V went down the wrong line. Aside from a possibly bad ITE chip.
    Chuck
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: HP Quanta U99 Board - 15F Series Laptop - Dead
    EC/KBC (the ITE chip) definitely got fried. I think EXA/EXS does not matter, i have performed this kind of replacement a couple times just matching the model number without paying any attention to the 3 letters at the end and it worked fine.
    If you replace the ITE chip it should work.
    A working TV? How boring!
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      well before removing it , try is simple functions , chek if SIO voltages are present , also chek S3 voltages , chek the starting voltage sequences as well .
      • katfish
        • Jul 2016
        • 76
        Just posting back my result. Not knowing if the other versions of the ITE chip might work, I went ahead and ordered identical ones from Hong Kong, couldn't find them elsewhere. Got several so I won't have to wait again. Anyway... got them in yesterday. Put the new one on this morning ... and bingo.
        Moral of the story, don't send 19v down your AD_ID line.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • max-power
          Dell E6540 laptop completely dead after dssasembly
          by max-power
          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
          03-24-2025, 08:49 AM
        • corrize
          Nikon D5 – dead, power board issue ?
          by corrize
          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
          Now, I try to understand how it works.
          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
          04-03-2023, 09:13 AM
