HP g6-2000 Series White Screen
  • mpikou
    • Jun 2013
    • 58
    • Greece
    A client of mine gave me an HP g6-2000 Series with a broken/hurt screen cable. The screen cable's have been short-cuted for sure, here is a photo:
    I have replaced the screen cable with a new one, and also a new screen, but i get "white" on screen. At external screen no signal at all.
    So, the issue must be of the board. With optical observation i dont see anything burned on board.
    Might anyone knows what i should check ?
  • sancheti81
    • May 2014
    • 191
    • India
    Re: HP g6-2000 Series White Screen
    I think its pch problem
    • mpikou
      • Jun 2013
      • 58
      • Greece
      Thank you for the reply.
      Could you please show me witch component is that ?
      Here are the pictures of the board:
      • sancheti81
        • May 2014
        • 191
        • India
        Covered with silver heatsink near bios battery
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          https://www.badcaps.net/forum/showpo...2&postcount=12
          • nixi22
            • May 2016
            • 44
            • Croatia
            Only problem is, hi dosent have signal on external display which means probably defected gpu.Before trying to reflow anything check all voltages cpu,gpu,pch,ram.Post card woud be good for diagnose correct issues
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              usually on hp laptop its hard to force displayed to external monitor, till internal was ok first..
              • mpikou
                • Jun 2013
                • 58
                • Greece
                Thanks for the explanation. This must be replaced or reflow ?
                • meritosari
                  • Oct 2010
                  • 774
                  • Indonesia
                  I agree with nixi22.
                  The point is of link what I was give to you is step 4. This step explain about degutji has been solved the problem after checking voltage/signal on mobo, then he know what causing the problem.
                  Reflow or replace the chips is the last attempt to fix
                  • mpikou
                    • Jun 2013
                    • 58
                    • Greece
                    Okay, i will give a try!
                    • mpikou
                      • Jun 2013
                      • 58
                      • Greece
                      Might there is available a schematic of that board or anyone can show me the components that might are faulty ?
                      Because at that reference there is a different board /schematic.
                      • meritosari
                        • Oct 2010
                        • 774
                        • Indonesia
                        • harp
                          White screen repairs
                          by harp
                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                          05-13-2024, 03:43 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • EazyBone
                          Sharp LC-65Q620U White Screen
                          by EazyBone
                          Another TV topic!!
                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                          08-21-2024, 12:56 PM
                        • hcinne
                          Dell G15 ryzen edition black screen 2 amber 1 white
                          by hcinne
                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                          07-23-2024, 07:56 AM
                        • Chrissygizmo
                          Panasonic TX-48CX350B backlights but white screen , blank screen
                          by Chrissygizmo
                          Hi all, I’ve got a problem I hope someone can help me fixi.
                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                          01-11-2025, 03:18 PM
