Dell 3521 unusually short to ground
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    This is a common fault in this laptop due to i got 3 laps with same issue . once dc jack connect laptop gets power. 3v and 5v are ok. once i press the power button power light on and stay as same .nothing happen
    when i check 3v and 5v rail short to ground but it will disapir after 5 minits or when i connect some caps to ground in the same rail
    even its short i can connect my dc power supply no short to be shown even i can press the power button that time also power light stay on
    then i noticed some voltage is remaining in that rail and reducing little by little same like discharging fault
    flowing things done but still the same manner
    flash bios ec main
    changed io and reprogrammed
    changed 3v 5v regulator
    changed pch as well
    but no changed at all
    please help me to sort it out this matter
    sigpic
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Dell 3521 unusually short to ground
    could be bad mosfets and solid caps on 3v/5v regulator. the symptom appear if the board have age more than 3 years. this case due your DMM using battery 9v. if you measure resistance on some rails (i.e 19v vs gnd) look like you've charge the caps, but I'm not pretty sure, but you can try it than doing hard work on PCH
    • samanthban
      • Feb 2014
      • 253
      • Sri lanka
      Thanks for your reply ..I will check those as you said and reply back.
      sigpic
      • samanthban
        • Feb 2014
        • 253
        • Sri lanka
        Changed pc213,pc212.pq202,203,204,205 no luck
        sigpic
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          rsmrst releasing from io
          sigpic
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Did you checked display cable.
            • smali
              • Sep 2014
              • 287
              • Pakistan
              what about the other voltage when you press power button like RAM,CPU core .
              • smali
                • Sep 2014
                • 287
                • Pakistan
                check your ENTRIP1 and ENTRIP2 section.
                • retrorepair2
                  Dell E5470 LA-C631p - Short removed now turns on but no post/display
                  by retrorepair2
                  Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
                  Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
                  09-25-2025, 07:12 AM
                • playit
                  450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                  by playit
                  hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                  09-02-2023, 02:43 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Leefreeman97
                  Diagnosing short to ground issue. pcb from an e scooter
                  by Leefreeman97
                  Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
                  09-19-2025, 03:33 PM
                • aaronkatrini
                  DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                  by aaronkatrini
                  I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                  - Put the card in my testing motherboard and start running Heaven benchmark
                  - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                  - Try to start it again and I get a slight move from the PSU fan - a clear short
                  - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                  - Put the...
                  05-18-2025, 04:18 PM
