Honton HT-R490 3 Zone BGA Rework Station
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    hi,
    any idea about this machine, i want to buy new bga station,
    someone have buy this product , i want your advise about it.
    thanks
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Honton HT-R490 3 Zone BGA Rework Station
    3 zone are the best, i own a Scotle 360 V3 and this is a beast !
    • polytek
      • Dec 2013
      • 496
      • TUNISIA
      thankyou passete,
      i have two ir6000 for 4 year ago , and they are not precise, despite they have thermocouple k,
      always i need to adjuste the profile. thatsway i decide to buy new one.
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        With my V3, i always use hot air on Top, with the right size nozzle, then i can adjust +/- 10° on the fly, using the Top Hot air potenciometer, 1 profille fits almost all
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          ok , i will order 3 zone, and i see the Hot Plate for reballing, but i'm not sure about this ;
          http://www.amazon.com/HT-1212-Reball.../dp/B00GN1ERJ0
          • diif
            • Feb 2014
            • 6978
            • England
            Seems expensive, I paid about £70 for mine from Aliexpress or maybe ebay, i forget.
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              I can do the same with my station, no need for this !
              But it's your £$€ ...
              • vinceroger69
                • Mar 2012
                • 6714
                http://de.aliexpress.com/item/HONTON...337859461.html
                • polytek
                  • Dec 2013
                  • 496
                  • TUNISIA
                  thanks a lot for the link.
                  • polytek
                    • Dec 2013
                    • 496
                    • TUNISIA
                    alright, friend i will forgot this,
                    • sopik78
                      • Nov 2013
                      • 519
                      • Czech Republic
                      I own HT-R392, which uses the same heaters as I can see on pictures. It is really amazing reworkstation, you will love it. Hot air is much better than IR, much accurate and you will never see popcorned chips.
                      • polytek
                        • Dec 2013
                        • 496
                        • TUNISIA
                        thankyou friend, for advise, i will order this honton.
                        • shahnld
                          wds-580 rework station issue
                          by shahnld
                          Good day.
                          i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                          Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                          kind regards...
                          03-28-2024, 01:14 PM
                        • minimania
                          Need Schematic for jbc am6800 rework station
                          by minimania
                          hi all im looking for a Schematic for jbc am6800 rework station
                          mine has stopped working fully
                          it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                          now it wont turn on at all...
                          01-28-2025, 03:44 PM
                        • shahnld
                          Seamark ZM-R6200 Rework station
                          by shahnld
                          Good day Experts.
                          I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                          Kind regards
                          01-24-2024, 10:55 AM
                        • petemanuk
                          Help with IR6500 rework station
                          by petemanuk
                          I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                          1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                          2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                          10-14-2022, 12:31 AM
                        • howardc64
                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                          by howardc64
                          Problem
                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                          Model & Board Pics
                          Conflicting Spec
                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                          https://www.shopjimmy.com/vizio-gj-2k1...
                          10-10-2024, 01:16 PM
