Dell 5010 graphic to non graphic please tell me.
  • trusharpatel
    • Nov 2012
    • india
    How to converted dell 5010 motherboard graphic to non graphic. Please described ...
  • rjcp
    • May 2016
    • 10
    • India
    Re: Dell 5010 graphic to non graphic please tell me.
    what do you mean?
    • mehtabbukhari
      Lets help
      • May 2016
      • 26
      • India
      As far as I understand "trusharpatel" wants to disable on board GPU and want to use Intel Graphics.
      But, as per my knowledge this is only possible where Hybrid graphics is supported because in Non Hybrids boards North bridge is without graphics capability.
      Correct me if I am wrong.
      • polytek
        • Dec 2013
        • 496
        • TUNISIA
        hi bro,
        look here it' s done
        https://www.badcaps.net/forum/showthread.php?t=48524
        • mehtabbukhari
          Lets help
          • May 2016
          • 26
          • India
          Hi Bro,
          Thanx, it s enlightening. But question is has anyone tried it and does it work?
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • sahamipoor
            how to Set graphic Discrete mode motherboard(no UMA) Dell XPS L502x - DAGM6CMB8D0
            by sahamipoor
            hello...
            the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
            i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
            according to ُSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
            1- EXT_LCD_PWM no voltage to enable pwm
            2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
            and screen is turn off and fan is high Speed!!
            Question:
            I need to Use Discrete graphic nvidia EXT_LCD ports...
            03-12-2024, 02:51 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
            Dell Thunderbolt Firmware
            by SMDFlea
            Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
            Some models have a choice of 2 different firmwares, it depends on the dell SKU.
            The SKU is in brackets (****)
            EDIT: NVM65...
            01-26-2025, 06:22 AM
