Hp touchsmart 300 black screen
    Hello friends.
    I need you assistance with this computer.
    So far.
    The computer boot right.
    The 2 fans working good.
    But the screen remain black.
    Checked.
    I remove - re-connect the bios battery, hard drive, memory and still can get picture.
    When i get this computer i noticed the fans was with plenty dirt even the heatsink.
    I think this computer was overheating.
    I check the processor and video chip and after 15 seconds feels like are working because generate heat on the top.
    I remove the memory and as soon the computer turn on, can't hear beep coming the pc, so, do you think the motherboard is bad???
    I check the voltage with to the led connector and show 3.2v
    any ideas??
    Re: Hp touchsmart 300 black screen
    I dont think s the chip but you can reflow it and see, but first try to flash the bios, it could be some bios issue.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
      Is caps lock blinking? How many times before it makes a longer pause?
        I did the reflow.
        Can i try twice (the reflow) ?
        How can i flash the bios?
          Originally posted by crdz66 View Post
          I did the reflow.
          With a Bios programmer .
          You need to desolder the Bios ic put on programmer, read (backup), erase and flash, then resolder back
            Update.
            You guys recommend to buy a new motherboard or can be something wrong with the screen?
              I check another things
              checked the inverter board and I get 12v on v_in connectors means good. (from motherboard)
              fuse is ok. (on inverter board)
              how can I check the voltages after the transformers if that ones are working good?
              ac on multimeter show me .182v on 4 tracks after the transformers.
              is that ok?
                i could test your bios.. if you get a spi programmer there is some pins for SPI header connection to read bios.
                read 2 copies and compare in Hxd Hex editor.
                post the file here and i burn to a pc im working on and if it works then we know its not bios..
                then again you probably wont see this for days.
