MSI GE60 2OE Turns on and off
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello guys, i have here 2 motherboards from a MSI GE60 2OE-072XFR
    Motherboard : MS-16GC1 VER 1.1
    Both mobos turns on and off very fast, no fan no nothing ....
    There is 3 Bios Chips, Main, KBC and VGA, can anyone post a dump please ?
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: MSI GE60 2OE Turns on and off
    I'm adding that both mobo's detects the battery and charge !
    I've found the 3 bios Dumps, but i'm suspecting that isn't the same VGA chip, cause my VGA bios is 128Kb and the one found is 256Kb.
    Help Please
    • Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
      by Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
      03-15-2024, 09:37 AM
    • www
      LG L192WS-BN backlight turns off after 1 second
      by www
      I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
      I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
      03-24-2024, 05:26 PM
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
    • andrhouseolly
      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
      by andrhouseolly
      Hi.
      I kindly ask you to help me solve the problem.
      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
      The board turns on, there is no image.
      Read more. When the power supply is connected, the front panel indicators light up briefly.
      When you press the power button, the button indicator lights up. The board works
      there is no image, there is no matrix initialization, there is no image on HDMI.
      When turned on, the fans do not spin, but when they warm up they start spinning.
      When you turn off the button, the fans spin up to full speed for a short...
      05-11-2024, 03:14 PM
    • Egidio85
      Samsung UE55F8000SZ Turns on and off immediately
      by Egidio85
      good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
      This defect happens continuously, hearing the classic click of the relay every time.
      Power supply board BN44-00636B
      disconnecting the mains and lamps from the power board always causes the same problem.
      Is it normal that without anything connected this power supply turns on and off cyclically?
      any suggestions on what to check?
      thanks in advance
      03-11-2025, 12:45 PM
